Oscillation with friction - Analytical mechanics
The discussion revolves around analyzing a damped harmonic oscillator described by the equation m ddot{x} + alpha dot{x} = -kappa x, with a specific condition on the friction parameter. The proposed solution involves expressing the general solution as x(t) = e^(-alpha t / 2m)[A t + B], with constants A and B defined by initial conditions. Feedback suggests verifying the solution by substituting it back into the original equation, indicating that the provided solution may not correctly represent a damped oscillator due to the absence of oscillatory terms. The conversation highlights the critical damping case as a key aspect of the analysis. Overall, the thread emphasizes the importance of validating solutions in analytical mechanics.
NODARman
Hi, I had those exercises and want to know if they're correct. Also, feedback/tips would be great from you, professionals.
$$A$$
1. Let's consider the oscillator with a friction parameter...
\begin{equation}
m \ddot{x}+\alpha \dot{x}=-\kappa x
\end{equation}
but with
\begin{equation}
\alpha^2=4 m \kappa
\end{equation}
and after inserting, show that the general solution will be like this:
\begin{equation}
x(t)=\mathrm{e}^{-\alpha t / 2 m}[\mathcal{A} t+\mathcal{B}]
\end{equation}
Express A and B constants with the initial coordinates and velocity and analyze.
My solution:\begin{aligned}
&m\ddot{x} + \dot{x}\sqrt{4mk} +kx=0\\
&x(t)=e^{-\frac{\alpha t}{2m}}[\mathcal {A}t+\mathcal{B}]\\
&\dot{x}(t)=-\frac{\alpha}{2m} e^{-\frac{\alpha t}{2m}} [\mathcal {A}t+\mathcal{B}]+e^{-\frac{\alpha t}{2m}}\mathcal{A}\\
&\ddot{x}(t)=-\frac{4\mathcal{A}\alpha m-\mathcal{A}{\alpha^{2}}t-\mathcal{B}{\alpha^{2}}}{4m^2}e^{-\frac{\alpha t}{2m}}\\
&x(0)=\mathcal{B}\equiv x_0 \\
&\dot{x}(0)=-\frac{\alpha}{2m} \mathcal{B}+\mathcal{A} = -\frac{\alpha}{2m} x_0 +\mathcal{A} \\
&\mathcal{A} = \dot{x}_0 + \frac{\alpha}{2m} x_0\\
&x(t)=e^{-\frac{\alpha t}{2m}}[\dot{x}_0 + \frac{\alpha}{2m} x_0 t+x_0] = e^{-\frac{\alpha t}{2m}}\left[\dot{x}_0 + \left(\frac{\alpha}{2m} t+1\right)x_0\right]\\
\end{aligned}
NODARman said:
Homework Statement: .
Relevant Equations: .
##\dots## and want to know if they're correct.
How about substituting your solution back in the original equation? That's the first thing I would do to verify my solution. Needless to say this doesn't look right because you have a damped harmonic oscillator with no oscillatory term(s) in the equation.
It should turn out to be the critical damping case.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
