pinsky
- 96
Centers of masses of planets mass m1 i m2 and radius r1 i r2 are standing still on a distance l. What is the distance between point T (which is located on a place where graviation is 0) and the surface of the first planet?
How much work do we do if we move a body of mass m from the surface of the first planet to the point T?
If we pull a guide perpendikulat to the path that connects the centers of masses of the planets, in the point T and give a small push to the mass, what is the frequency of oscillation?
(the guide is just an object which prevents the mass from going anywhere else than up or down)
[PLAIN]http://img201.imageshack.us/img201/5030/titranjemedjuzvezdama.gif
a) solved, which means that l1 and l2 are known values
b) (s is the distance variable, l1 is the distance between the surface of the first planet and point M)
[tex]dA=F ds [/tex]
[tex]F=F_1+F_2 [/tex]
[tex]F_1=G m_1 m /s^2 [/tex]
[tex]F_2=G m_2 m /(l-l_1-l_2-s)^2 [/tex]
[tex]A=G m_1 m \int_0^{l_1} \frac{1}{s^2}+G m_2 m \int_0^{l_1} \frac{1}{(l-l_1-l_1-s)^2}[/tex]
If i integrate that i get infinite work done. Hints?
c)
[PLAIN]http://img217.imageshack.us/img217/7312/titranjemedjuzvezdama2.gif
[tex]F_{1y}=Sin(\varphi_1) \frac{ G m_1 m }{r_1^2} \\ [/tex]
[tex]F_{2y}=Sin(\varphi_2) \frac{ G m_2 m }{r_2^2} \\ [/tex]
[tex]y=r_2 Sin(\varphi_2)=r_1 Sin(\varphi_1)[/tex]
[tex]F(y)=ma=my''[/tex]
I should just write Newtons law and get a differential equation for oscillation, but i don't have a linear connection between the force and the displacement y. Hints?
