Oscillations concerning a pendulum
In summary, a clock on a spaceship accelerating from the surface of the Earth with an acceleration of 3g has a pendulum that experiences a force of 4mg. Using the formula T = 2π√(L/g), the period of vibration of the pendulum can be calculated to be 1 second. The correct method for finding the force acting on the pendulum is to consider the pseudo force on the pendulum by Newton's first law.
Alex_Neof
41
A clock is regulated by a pendulum. The pendulum can be considered as a small weight connected to a rod of negligible mass. The period of oscillation of the pendulum can be adjusted by moving the weight up or down the rod. The angular frequency is given by ##\omega ^2 =\frac{g}{L}##, where ##L## is the distance between the centre of the small mass and the pivot point of the pendulum.
The clock is placed on a spaceship accelerating from the surface of the Earth with
acceleration ##a=3g.## Calculate the period of vibration of the pendulum.
##T = 2 \pi \sqrt{\frac{L}{g}}##
The net acceleration is 2g.
Therefore,
## T = 2 {\pi} \sqrt{\frac{(50 \times 10^{-2})} {(2g)}} ##
##T = 1.003544 = 1 s##
Does this seem correct?
Thank you!
How did you get this?
Alex_Neof said:
The clock is placed on a spaceship accelerating ##from~ the~ surface~ of~ the~ Earth## with
acceleration a=3g.a=3g.
##\sum F_y = ma = -mg + 3mg ##
##ma = 2mg ##
##a = 2g##
Taking forces radially downwards as negative.
Try to find the force acting on a body inside the shuttle rather than the total force acting on the space ship
Hint: you should consider pseudo force on the pendulum by Newtons 1st law
Likes Alex_Neof
Suraj, is this correct?
##\sum {F_y} = m(3g) = - mg + T ##
## T = m(4g) ##
So,
## a = 4g ##
Therefore,
## T = 0.71\ seconds##
Thank you.
Likes Suraj M
Thank you !
Alex_Neof said:
a=4g
As you have taken forces downward as -ve ypu should be getting a as a -ve value, which you're not,
What is the T you have introduced?
also ##∑F_y ≠m(3g)##
you got the right answer, but i doubt the method you have used..i do not mean to discourage you, but its better to know the right method, so that you can use it for another question.
Oh, the T is the tension of the string, which is upwards. How would I go about this? It's true I would rather know the method so I can apply the method again in the future.
Thats a good way to find out the total force acting on the bob, your T should be the resultant of 2 downward(-ve) forces, could you recognize those forces?
sorry, since the rocket is accelerating upwards at 3g, does that mean the clock inside is also accelerating upwards at 3g?
We'll it is, but when you're standing in a bus and the vehicle is accelerating forward at 5m/s² will you feel a forward force acting on you, or a backward force? apply your findings to the bob.
So the bob will 'feel' a force of 3mg downwards. Adding this to its weight mg will result in the tension being 4mg upwards.
yes the tension is 4mg upwards which is the one which balances out the downward force experienced by the bob, so you can get your new g' = a=-4g .. and you'll have your answer.
Just remember about the concept of pseudoforce in cases like this, body feels a force equal and opposite to the direction of its (accelerated) motion.
:smile:
Likes Alex_Neof
Thanks again Suraj.
Kind regards and all the best!
You're welcome, :smile:
All the best to you too .
Related to Oscillations concerning a pendulum
What is a pendulum?
A pendulum is a weight suspended from a pivot point that swings back and forth due to the force of gravity. It is commonly used in clocks and other timekeeping devices.
What is the period of a pendulum?
The period of a pendulum is the time it takes for one complete swing, from left to right and back to left. It is affected by the length of the pendulum and the strength of gravity.
What is the relationship between the length of a pendulum and its period?
The length of a pendulum and its period are inversely proportional. This means that as the length of the pendulum increases, the period also increases. This relationship was discovered by Galileo Galilei.
What factors affect the period of a pendulum?
The period of a pendulum is affected by the length of the pendulum, the mass of the weight, and the strength of gravity. Air resistance and friction can also have a small effect on the period.
How is a pendulum used to measure time?
A pendulum can be used to measure time by counting the number of swings it makes in a certain period. By adjusting the length of the pendulum, it can be made to swing at a specific rate, allowing it to function as a clock or timer.
