Oscillator using ad829 works - trying to make it work using 741
In summary: This is an oscillator that can use a voltage supply lower than the supply voltage of the AD829. I will try to get the schematic attached so you can see.
  • #36
FOIWATER said:
Vo as 20 v I load as 4 A
I understand about the op amp now.
Sure I understand now, this driver needs a higher voltage, right?
But it's only rated for 20,
Ok I see, for such a large load current L1 value looks good.
As for the high side driver you can use this one.
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=printview&t=128299&start=0
Likes 1 person
  • #37
I need a high input to turn on the mosfet. This seems like a different scenario, no?
I guess.. a high signal IS technically turning on the mosfet.. but it's a low signal from the driver which accomplishes it?
  • #38
This circuit will do the job
  • #39
I wouldn't feel right using it outright. But I will try my best to learn from it. Thanks, Jony
Do these circuits eliminate the need for a driver??
I am lost here
  • #41
How about if I use a separate supply for the driver and ground the source of the MOSFET.
If this will work, will 5 volts be enough?
  • #42
You want to use a floating power supply for a MOSFET ?
  • #43
for the driver, will that work?
  • #44
If you don't want to use this discrete MOSFET driver. I think you should try to use IR2011. You can power it from 12V power supply you already have in your design.
  • #45
Really.. but as you said, 12 volts to the gate of the MOSFET will not allow me to have 28 volts at the source?
I will have 12 - Vgs only, no?
I don't think I understand drivers
  • #46
But IR2011 has high side driver with external diode and capacitor. And this will boost the gate voltage up to
28V + 12V.
  • #47
I did not know this thanks Jony
