Osmolarity of water in red blood cells?
In summary, the osmolarity of a cell can cause it to swell, shrink, or burst depending on the concentration of solutes inside and outside the cell. When there is a higher concentration of solutes outside the cell, water will move out of the cell, causing it to shrink. Conversely, when there is a lower concentration of solutes outside the cell, water will move into the cell, causing it to swell. In the case of adding urea to a cell, the urea bonds with water molecules, decreasing the external concentration of water and causing the water inside the cell to flow out, resulting in the cell shrinking.
GoGoGadget
31
I am confused on how osmolarity of cells with water would cause a cell to swell, shrink, or burst. I know that a cell has a solution concentration of 300 mosm. In a lab that was done, we analyzed the impact of a red blood cell in solutions containing different osmolarities. For example, when a red blood cell was placed into a 400 mM ethanol penetrating solution and 0 non-pentrating solutes, the cell would burst and shrink as the water doesn't leave the cell. In another example, when the cell was placed into a 1400 mM solution of NaCl, the cell was found to shrink because water moved down it's concentration gradient with the higher osmolarity of the outer solution. Finally, when a red blood cell was placed into a solution containing a 700 mM penetrating amount of urea and a 700 mM nonpentrating amount of NaCl, the urea moved into the cell and the cell was found to shrink. I'm really confused on why this would be the case. Is it because the urea moving into the cell makes the molar concentration of solute outside the cell lower then in the cell so the water would move down its concentration gradient for that reason? Any help is very much appreciated.
...the urea moved into the cell and the cell was found to shrink. I'm really confused on why this would be the case. Is it because the urea moving into the cell makes the molar concentration of solute outside the cell lower then in the cell so the water would move down its concentration gradient for that reason?
I can see why you would be confused about adding urea to a cell and it getting smaller.
When fluid enters a cell, it be comes hypotonic, causing it to expand or lyse
When fluid leaves a cell, the cell becomes hypertonic, causing it to shrink.
Fluid exchange will occur when cellular concentrations are not favorable with external and internal equilibrium conditions. Molecular weight should also be taken into consideration, as larger molecules will not be able to permeate the cell membrane.
By comparing the internal and external concentrations, we should be able to understand the direction of flow with respect to the concentration gradient.
Urea will bond via electrostatic interactions with several H2O molecules. Since we have used urea to tie up the external water molecules, there is a decreased external concentration of water. Thus, the internal water molecules from the erythrocyte are in higher concentration. The water volume from the RBC is decreases as the water follows the concentration gradient outside of the cell into the system.
Related to Osmolarity of water in red blood cells?
1. What is osmolarity and how does it affect red blood cells?
Osmolarity refers to the concentration of solutes, such as salts and sugars, in a solution. In the case of red blood cells, osmolarity is important because it affects the movement of water in and out of the cells. If the osmolarity of the surrounding fluid is higher than that inside the cells, water will move out of the cells, causing them to shrink. Conversely, if the osmolarity of the surrounding fluid is lower than that inside the cells, water will move into the cells, causing them to swell and potentially burst.
2. How is the osmolarity of water in red blood cells measured?
The osmolarity of water in red blood cells is typically measured using a technique called osmometry. This involves placing a small sample of red blood cells in a solution of known osmolarity and measuring the change in volume of the cells. The osmolarity of the red blood cells can then be calculated based on this change in volume.
3. What is the normal osmolarity of water in red blood cells?
The normal osmolarity of water in red blood cells is around 300 mOsm/L (milliosmoles per liter). This is the same as the osmolarity of human plasma, which is the fluid component of blood.
4. How does osmolarity impact the function of red blood cells?
Osmolarity is crucial for the proper functioning of red blood cells. If the osmolarity of the surrounding fluid is not within a narrow range, it can lead to changes in the shape and size of the cells, which can affect their ability to transport oxygen and carbon dioxide throughout the body. Extreme changes in osmolarity can also cause red blood cells to rupture, leading to anemia and other health problems.
5. What factors can influence the osmolarity of water in red blood cells?
The osmolarity of water in red blood cells can be influenced by a variety of factors, including the concentration of solutes in the surrounding fluid, the health and integrity of the cell membrane, and the activity of certain transport proteins that regulate the movement of solutes in and out of the cells. External factors such as temperature and pH can also impact osmolarity and therefore affect the function of red blood cells.
  • Biology and Medical
12K
