I Outer layer refractive index - total internal refection on waveguide
The discussion centers on the use of waveguides in augmented reality (AR) lenses, specifically the role of outer layers with lower refractive indices to facilitate total internal reflection. This design choice enhances light transmission by allowing a smoother transition between materials, which helps suppress higher order modes that can distort signals. The conversation also touches on the benefits of step-index and graded index optical fibers for fast digital transmission. Additionally, there is a request for clarification on the term "AR lens," questioning whether it refers to a gradient index lens, an augmented reality filter, or an antireflective coating. Overall, understanding these optical principles is crucial for optimizing AR lens performance.
Rymazon
TL;DR Summary
Could an extra layer be better than air?
I am interested in experimenting with AR lenses and one of the main technologies is a waveguide. They rely on total internal reflection, which needs light to go from a higher to lower refractive index medium. I am reading that current AR lenses use an outer layer with a lower refractive index to allow this to happen but why would this be better than having no outer layer and using the refractive index of air, which is lower than most transparent materials? Thanks.
Science news on Phys.org
As you will realise there are a number of modes that can propagate in an optical waveguide. By making the transition in refractive index at the boundary gentle, those modes having a small angle of incidence at the interface will not be reflected and will pass through. The waveguide then tends to suppress higher order modes. This is desirable for some applications because the higher order modes propagate more slowly and will tend to blur a short signalling pulse. Step-index and graded index optical fibre are useful for fast digital transmission.
Please define "AR lens". Do you mean gradient index lens? Or augmented reality filter? Or antireflective coating on glass lens?
Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA)Please define acronyms (PDA) Please define acronyms (PDA) Please define acronyms (PDA).......
  • Love
Likes nasu and vanhees71
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
