Overall Force Acting on a Submerged Cube (in water)
In summary, the question involves determining the overall force acting on a submerged cube with a given density in water. The solution involves considering the pressure differences on the top and bottom faces of the cube and using Archimedes' principle to calculate the net buoyancy force. The answer should also include the effect of gravity on the cube.
FaraDazed
347
This is not homework or coursework. I have an exam coming up and this question is from a past paper and I am unsure why but it is confusing me a bit.
A cube of side 0.3m which has an average density of 4500 kg/m^3 . Determine the overall force acting on the cube when it is submerged in water.
Density of water is given to be 1000 kg/m^3
[itex]
p=h \rho g \\
[/itex]
Upthrust = [itex] \rho g V = \rho g l^3 [/itex]
The main reason I am confused is because I thought one would need to know the depth, h, the cube is submerged at?
I understand that one only needs to consider the forces acting on the top face and bottom face because the others cancel out but again, I have no idea how I am supposed to do that without knowing the depth.
Is it simply that the total force is equal to the upthrust? Because that's the only equation I can think of that does not include the depth.
If so then it is simply
[itex] \rho g l^3 = 4500 \times 9.81 \times 0.3^3 = 1192 N [/itex]
Also, is there a symbol used to represent upthrust or is it simply something like F with a subscript?
Any help appreciated. Thanks :)
I'm no sure what you mean by "submerged under water". Since an ice cube normally floats if left to itself, there would be a net upward force causing it to rise to the surface. If the ice cube is being held at a specific depth then obviously the net force is 0.
If the ice cube is not being held at a specific depth then use Archimede's principle: Subtract the mass of the ice cube from the mass of water it displaces. That, times "g", gives the upward force on the ice cube.
No, you do not need to know the depth. Pressure on top of the cube is going to push the cube down. Pressure on the bottom of the cube is going to push it up. The net buoyancy force is going to be the difference between those forces and as the top and bottom faces have the same area, it follows that the difference is proportional to the pressure difference between the top and bottom of the cube, which depends on the height of the cube - not on the overall pressure.
The cube has a specific gravity of 4.5, it is not made of ice ... :smile:
I don't know sorry, that is the exact wording on the exam paper.
Isn't the equation for upthrust I used the result of Archimede's principle?
Right OK, that makes it a little clearer for me thanks. So is the answer I got correct do you know?
Thanks
Your answer would be the force from the pressure of the water on the cube. Is there perhaps another force which is also acting on the cube?
Regarding Archimedes' principle: Your formula is correct. Just remember that when an object is only partially submerged, the volume that should be used is the volume of the part of the object that is below the surface.
Regarding Archimedes' principle: Thanks, I assumed in this question that is was completely submerged as it did not say otherwise.
Reading the question, that is what I took it to mean, the force of the water acting on the cube. I cannot think of any other force, apart from gravity.
The question asks for the "overall force". I would take this to mean the net force on the cube, which definitely should include gravity. If only the force from the water was asked for, it would most likely say something to the effect of "force of the water on the cube" or "buoyancy".
Ok fair enough. Isn't gravity already taken into account though? Since [itex]mg=\rho V g [/itex]?
The main reason I thought that the wording meant only the forces of water on the cube is because on the exam paper this is part iiib of one question all about buoyancy and the Archimedes principle.
There are two forces acting on the cube, one is the pressure from the water, which is in the up direction and is given by the weight of the displaced water through Archimedes' principle (positive direction up)
F_{\rm pressure} = \rho_{\rm H_2O} Vg.
The other is the gravitational force on the cube due to its actual mass, which is given by (again, positive direction up)
F_{\rm gravity} = -m_{\rm cube} g = -\rho_{\rm cube} V g.
The net force on the cube is the sum of these
F_{\rm net} = V g (\rho_{\rm H_2O} - \rho_{\rm cube}).
Among other things, this tells us that the cube would be floating freely around without any net force acting upon it (if water drag is neglected) if it had the same density as water.
Right ok thanks, that's cleared it up a little. So my original answer is that the force of the water on the cube or gravity because I used the density of the cube rather than the density of water.
Thanks,
Your original numerical answer would be the gravitational force on the cube and does not include the force from the water on the cube.
Related to Overall Force Acting on a Submerged Cube (in water)
What is the overall force acting on a submerged cube in water?
The overall force acting on a submerged cube in water is equal to the weight of the water displaced by the cube.
How is the overall force calculated for a submerged cube in water?
The overall force can be calculated using Archimedes' principle, which states that the upward buoyant force on an object equals the weight of the fluid it displaces. In this case, the fluid is water and the object is the submerged cube.
What factors affect the overall force acting on a submerged cube in water?
The overall force acting on a submerged cube in water is affected by the density of the water, the volume of the cube, and the depth at which the cube is submerged. It is also affected by the gravitational acceleration of the Earth.
Does the overall force acting on a submerged cube in water change with depth?
Yes, the overall force acting on a submerged cube in water changes with depth because the pressure of the water increases with depth. This means that the weight of the water displaced by the cube also increases, resulting in a greater overall force.
How does the overall force acting on a submerged cube in water relate to its stability?
The overall force acting on a submerged cube in water plays a significant role in its stability. If the overall force is greater than the weight of the cube, it will float and be stable. However, if the overall force is less than the weight of the cube, it will sink. The placement of the center of mass and center of buoyancy also affect the stability of the cube.
