roldy
- 237
- 2
The band levels for a noise are 70 dB reference 20[tex]\mu[/tex]Pa at 31.5 Hz and decrease 3 dB for each octave. Find the overall sound pressure level between 31.5 and 8000 Hz and the A-weighted sound pressure level for this frequency range.
[tex]SPL=20\frac{P_{rms}}{P_{ref}}[/tex]
I think my misunderstanding of the problem is prohibiting me from calculating the correct answer.
I used excel to do the calculations
The band level noise for each octave are as follows
31.5 Hz: 70 dB
63 Hz: 67 dB
125 Hz: 64 dB
250 Hz: 61 dB
500 Hz: 58 dB
1000 Hz: 55 dB
2000 Hz: 52 dB
4000 Hz: 49 dB
8000 Hz: 46 dB
The reason I did this was because the problem stated that the band level noise decreased 3 dB for each octave.
Then I added in the corrections to the dB values above. The correction values for each octave band level are as follows.
31.5 Hz: -39.4 dB
63 Hz: -26.2 dB
125 Hz: -16.1 dB
250 Hz: -8.6 dB
500 Hz: -3.2 dB
1000 Hz: 0 dB
2000 Hz: 1.2 dB
4000 Hz: 1.0 dB
8000 Hz: -1.1 dB
The final dB values:
31.5 Hz: 30.6 dB
63 Hz: 40.8 dB
125 Hz: 47.9 dB
250 Hz: 52.4 dB
500 Hz: 54.8 dB
1000 Hz: 55 dB
2000 Hz: 53.2 dB
4000 Hz: 50 dB
8000 Hz: 44.9 dB
I then square them
31.5Hz: 936.36
63 Hz: 1664.64
125 Hz: 2294.41
250 Hz: 2745.76
500 Hz: 3003.04
1000 Hz: 3025
2000 Hz: 2830.24
4000 Hz:2500
8000 Hz: 2016.01
Then the average
2335.051111
and then square root
48.32236657
This gives me the rms pressure value for 31.5 to 8000 Hz. I then use the equation
[tex]SPL=20log\frac{P_{rms}}{P_{ref}}[/tex] to find the overall sound pressure level. The answer I get is 127.66 dB. The correct answer is 73.0 dB and the A-weighted value is 60.8 dBA. What did I do wrong?
