SevenToFive
- 56
- 3
I have a hollow output shaft gearbox that will accept a 1-1/8" solid shaft, I want to extend the output shaft of a gearbox by 6 inches from the face of output seal to the end of the shaft. The manufacturer states that gear reducer is rated 899 lbs with the hollow shaft or a solid shaft that extends 2.36 inches from the face of the output seal. I am looking for the shaft to support 200 lbs. I want to calculate the overhung load but all of the equations that I find seem to focus around having a pulley or sheave at the end of the standard output shaft, but we will not be adding a pulley or sheave to the end of the shaft. The equation in the gearbox manufacturers catalog is (HP*126000*Overhung Load Factor)/Pitch Diameter*Output RPM. The distance from the output seal/bearing must play a large roll in the amount of overhung load the gear reducer can take.
Does anyone have an equation I can use?
Thanks
Thanks
