Oxidation Number to balance a redox reaction
In summary, the conversation discusses balancing the chemical equation Cl2+NaOH -> NaCl + NaClO3 + H2O by determining the oxidation numbers of all species. It is determined that 3 atoms of Cl and 6 atoms of Na are required to equalize the oxidation numbers, resulting in the balanced equation 3Cl2 + 6NaOH -> 5NaCl + NaClO3 + 3H2O. The concept of disproportionation is also mentioned.
agnibho
46
Balance Cl2+NaOH -> NaCl + NaClO3 + H2O
Start by determining the oxidation numbers of all species.
Cl02 + Na+1O-2H+1 -> Na+1Cl + Na+1Cl-1O3-2 + H2+1O-2
To equalize the Oxidation Numbers of Cl and Na, 3 atoms of Cl and 6 atoms of Na are required. Thus,
3Cl2 + 6NaOH -> 5NaCl + NaClO3 + xH2O
By inspection x = 3
∴ 3Cl2 + 6NaOH -> 5NaCl + NaClO3 + 3H2O
I think this is correct, but if I have done something wrong please tell me so, as I'm new to this topic.
Thanks in advance.
No idea what you mean by "equalize the ON", specially in the context of sodium - ON for sodium doesn't change, and Na+ is only a spectator.
You have Cl(0) on the left and Cl(+1) and Cl(-1) on the right. This is disproportionation - teh same element becomes both oxidized and reduced at the same time. Can you tell how many atoms of Cl get oxidized if 1 atom gets reduced?
In order to balance a redox reaction, we must first determine the oxidation numbers of each element involved. In this reaction, chlorine (Cl) has an oxidation number of 0 in its elemental form. Once it combines with sodium hydroxide (NaOH), it becomes -1 in NaCl and +5 in NaClO3. On the other hand, sodium (Na) has an oxidation number of +1 in both NaOH and NaCl, and hydrogen (H) has an oxidation number of +1 in H2O.
To balance the reaction, we need to make sure that the total charge on both sides of the equation is equal. In this case, we can see that the total charge on the reactant side is 0 (2xCl2 + NaOH = 0) while the total charge on the product side is +1 (NaCl + NaClO3 + H2O = +1). To balance this, we can add 3 more NaOH on the reactant side, which will give us a total charge of -3 (2xCl2 + 3NaOH = -3). To balance the charge on the product side, we can add 3 more H2O, which will give us a total charge of 0 (+3NaCl + NaClO3 + 3H2O = 0).
Now, we can see that the equation is balanced in terms of charge, but we also need to make sure that the number of atoms on both sides is equal. To do this, we can add a coefficient of 2 in front of NaClO3 on the product side, which will give us a total of 2 NaClO3. This will also give us a total of 6 Cl atoms on the product side, which is balanced with the 6 Cl atoms on the reactant side.
Therefore, the balanced equation is 2Cl2 + 6NaOH -> 3NaCl + 2NaClO3 + 3H2O. This balanced equation satisfies both the charge balance and the atom balance, and represents the correct stoichiometry of the reaction.
Related to Oxidation Number to balance a redox reaction
1. What is an oxidation number?
An oxidation number is a positive or negative number assigned to an atom in a molecule or ion based on the distribution of electrons in its chemical bonds. It represents the hypothetical charge an atom would have if all its bonds were purely ionic.
2. How do you determine the oxidation number of an element in a compound?
The oxidation number of an element is determined by a set of rules that take into account the electronegativity of the atoms and their arrangement in the molecule. Some general rules include: elements in their elemental form have an oxidation number of 0, the oxidation number of a monatomic ion is equal to its charge, and the sum of oxidation numbers in a neutral molecule is 0.
3. Why is balancing oxidation numbers important in a redox reaction?
In a redox reaction, the oxidation numbers of the elements involved change. Balancing the oxidation numbers ensures that the number of electrons lost by one element is equal to the number gained by another, thus maintaining charge balance in the reaction.
4. How do you balance oxidation numbers in a redox reaction?
To balance oxidation numbers, you need to identify the oxidized and reduced elements in the reaction. Then, use coefficients to balance the number of electrons lost and gained by each element. In some cases, you may also need to add spectator ions to balance the overall charge of the reaction.
5. Can oxidation numbers be negative?
Yes, oxidation numbers can be negative. This usually occurs when an atom gains electrons in a redox reaction, resulting in a negative oxidation number. It is important to note that oxidation numbers are not the same as actual charges, and a negative oxidation number does not necessarily mean the atom has a negative charge.
