P.Chem1: Internal energy in isothermal, reversible reactions
In summary, the first problem involves a perfect gas expanding isothermally, resulting in a change in internal energy of 0. However, in the second problem, where a gas is being condensed to a liquid, the change in internal energy is not 0 due to the strong interactions between particles in a liquid. Additionally, for the second problem, the external pressure is assumed to be constant at 1.00 atm in order for the condensation to be reversible at 100 degrees Celsius.
Puchinita5
183
I have these two homework problems, as well as solutions. What I do not understand is why the solution for one is not the solution for the other.
First problem:
A sample consisting of 1.00 mol Ar is expanded isothermally at 0 deg Celc from 22.4 dm3 to 44.8 dm3 reversibly. Calculate q, w, delta U, and delta H. (heat, work, internal energy, and enthalpy)
Second problem:
A sample of 1.00 mol H20(g) is condensed isothermally and reversibly to liquid water at 100 deg Celc. The standard enthalpy of vaporization of water at 100 deg C is 40.646 kJ mol-1. Find w, q delta U, and delta H. (work, heat internal energy, and enthalpy)
Note: both problems refer to perfect gases
For the first problem, the solutions manual says that delta U is 0 since the internal energy of a perfect gas depends only on temperature, and since temperature is constant internal energy must be 0.
The second problem, however this is not the case. Why is the internal energy in the second problem not also zero if it is condensed reversibly and isothermally(which means constant T right?) ??
(emphasis mine)
The assumption that internal energy depends only on temperature applies only to perfect gasses. In problem two, you have a gas going to a liquid (not a gas). Therefore, because everything does not staying in the gas state, you cannot make the assumption that internal energy depends only on temperature.
A bit more details: The internal energy of a substance is composed of two components: the energy from the interactions between the particles composing the substance and the kinetic energy of the particles composing the substance. For a perfect gas, we assume that there are no interactions between particles, so the internal energy depends solely on the kinetic energy of the particles (which is directly proportional to temperature).
A liquid, however, has fairly strong interactions between the particles, so these interactions contribute greatly to the internal energy of a liquid. Even though the kinetic energy of the particles does not change when you convert a gas to a liquid at a constant temperature, the energy from the interaction between particles does change. Therefore, the internal energy changes.
oh wow. That was a great explanation, makes total sense!
If you wouldn't mind answering one more thing for me, for the second problem I'm a little unsure why we can assume (according to the solutions manual) that the external pressure is constant and equals 1.00 atm.
is the external pressure constant because it is reversible? I guess, does reversible mean any "change" in the pressure would be infinitesimally small, so basically constant P? I'm just not sure if my understanding of this is correct.
and are we assuming then that it would equal 1.00 atm because the external pressure is not given, so we just say 1.00 atm because that is about Earth's pressure at the surface?
or am I just totally making things up lol?
The pressure has to be 1 atm, because only at that pressure is the condensation of water reversible at 100oC. Changing the pressure will change the boiling point of water (i.e. the temperature at which the gas and liquid phases will be at equilibrium).
Of course, I probably wouldn't expect a student to necessarily remember this and it would probably be much better if the book actually gave you the pressure, but in theory, the question contains enough information to tell you that the pressure has to be 1.00 atm.
great, thank you so much! You were very helpful :)
FAQ: P.Chem1: Internal energy in isothermal, reversible reactions
1. What is internal energy in isothermal, reversible reactions?
Internal energy in isothermal, reversible reactions is the total energy of a system that can be interconverted between different forms, such as thermal, mechanical, and chemical energy. In these reactions, the temperature of the system remains constant and there is no net change in the system's internal energy.
2. How is internal energy related to enthalpy in isothermal, reversible reactions?
In isothermal, reversible reactions, internal energy and enthalpy are directly related. Enthalpy is defined as the sum of a system's internal energy and the product of its pressure and volume. Since the temperature remains constant in these reactions, the change in enthalpy is equal to the change in internal energy.
3. What is the significance of reversible reactions in studying internal energy?
Reversible reactions are important in studying internal energy because they allow for the precise measurement of the system's internal energy. This is because the system is in equilibrium throughout the reaction, meaning that the forward and reverse reactions occur at equal rates and there is no net change in the system's internal energy.
4. How does temperature affect internal energy in isothermal, reversible reactions?
In isothermal, reversible reactions, temperature has no effect on the system's internal energy. This is because the temperature remains constant throughout the reaction and the internal energy is dependent on the state of the system, not the temperature.
5. Can internal energy be measured directly in isothermal, reversible reactions?
No, internal energy cannot be measured directly in isothermal, reversible reactions. Instead, it is calculated by measuring the change in enthalpy and subtracting the work done by the system. This is because internal energy is a state function and can only be determined by changes in the system's state, not its absolute value.
