MHB P divides all the coefficients of the terms with degree <8
mathmari
MHB
Hey! :o
$f(x)=\sum_{i=0}^{7}{a_ix^i}, g(x)=\sum_{i=0}^{5}{b_ix^i}$, $a_i, b_i$ are integer coefficients.
The prime $p$ divides $a_0, a_1, a_2, a_3, a_4$ but it does not divide $a_5, a_6, a_7$. $p$ divides also $b_0, b_1, b_2$, but it does not divide $b_3, b_4, b_5$.
$h(x)=f(x)g(x)$
Show that at $h(x)$ $p$ does not divide the coefficient of $x^8$, but it does divide all the coefficients of the terms with degree $<8$.
We suppose that $p \mid c_8$.
$p \mid b_1 \Rightarrow p \mid a_7 b_1$
$p \mid b_2 \Rightarrow p \mid a_6 b_2$
$p \mid a_3 \Rightarrow p \mid a_3 b_5$
$p \mid a_4 \Rightarrow p \mid a_4 b_4$
$c_8=a_7b_1+a_6b_2+a_5b_3+a_4b_4+a_3b_5 \Rightarrow a_5 b_3=c_8-a_7b_1-a_6 b_2-a_4 b_4-a_3b_5$
$p \mid c_8-a_7b_1-a_6 b_2-a_4 b_4-a_3b_5 \Rightarrow p \mid a_5 b_3$
Since $p$ is a prime $p \mid a_5$ or $p \mid b_3$. Both are not true, so $p \nmid c_8$.
To show that $p$ divides all the coefficients of the terms with degree $<8$, what am I supposed to do? Do I have to calculate all the coefficients and find that $p$ divides them? Or is there an other way to show this?
mathmari said:
Hey! :o
$h(x)=f(x)g(x)$
Hii! ;)
I suggest to verify $c_7$ and make an argument for the others.
I like Serena said:
Hii! ;)
$c_7=a_7b_0+a_6b_1+a_5b_2+a_4b_3+a_3b_4+a_2b_5$
$p \mid b_0 \Rightarrow p \mid a_7 b_0$
$p \mid b_1 \Rightarrow p \mid a_6 b_1$
$p \mid b_2 \Rightarrow p \mid a_5 b_2$
$p \mid a_2 \Rightarrow p \mid a_2 b_5$
$p \mid a_3 \Rightarrow p \mid a_3 b_4$
$p \mid a_4 \Rightarrow p \mid a_4 b_3$
So $p \mid c_7$
What can I say for the others?
Note that:
$\displaystyle c_k = \sum_{i = 0}^k a_ib_{k-i}$
We will take $b_j = 0$ for $j > 5$.
If $k \leq 4$, then every term is divisible by $p$ since $p$ divides all the "$a$'s".
This leaves just 3 coefficients to check: $c_5,c_6,c_7$. We could manually compute them, but that seems like...ugh...work.
But notice that as the "$a$'s" count up, the "$b$'s" count down. So if the b terms take care of the a terms that aren't covered, every term in the sum will be divisible by $p$. And the LOWEST $k$ for which this happens is when the i in:
$a_ib_{k-i}$ is greater than 4, and the k-i in said term is greater than 2, that is:
$k = i + (k-i) \geq 5 + 3 = 8$.
Since 5,6 and 7 are all less than 8, $c_5,c_6,c_7$ are all divisible by $p$.
So $p \mid c_7$
As Deveno also remarked, we have low numbered $b_i$ that are divisible by $p$ or we have low numbered $a_i$ that are divisible by $p$.
For $c_7$ we have the worst case that still pans out.
So lower numbered $c_i$ will also be divisible by $p$.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
