P & Q branches confusion in rovibrational transitions + rant
  • I
  • Thread starter misko
  • Tags
    Confusion
In summary, the two branches of spectral lines that are observed in rovibrational transitions are the R and P branches. The R branch is on the higher frequency side of the Q branch, and the P branch is on the lower frequency side.
misko
46
In rovibrational transitions we have following selection rules
$$ \Delta v = \pm 1 $$
$$ \Delta J = \pm 1 $$
where ##v## is the vibrational quantum number and ##J## is rotational quantum number.
Now based on whether ##\Delta J## changes to +1 or -1 we have two branches of spectroscopic lines.
They are defined as following:
- if transition happens such that ##\Delta J = +1## that goes in R-branch
- if transition happens such that ##\Delta J = -1## that goes in P-branch
It is also said (eg. https://en.wikipedia.org/wiki/Rotational–vibrational_spectroscopy) that R branch is on the higher frequency side of the Q branch and P branch is on the lower frequency side. This means that the lines in R branch have more photon energy (eg. less wavelength) than lines in the P branch.
So far so good.
But notice how I emphasized transition word above? That's because in every site/book I looked at I see they use word transition without specifying whether it's absorption or emission. It seems as if it doesn't matter but looks like it does.
If we have absorption and ##\Delta J = +1## (say J goes from 0 to 1) then that is R branch. But if we have emission (the same transition in opposite direction where J goes from 1 to 0) we will have ##\Delta J = -1##. Now both of these transitions must be of the same energy but which should go to the R branch? I conclude it must be that the transition specified above in the definition is absorption and not emission.
So why I couldn't find in any resource this? Why did I have to lose 3-4 hours on this trying to figure out all this rather than having a precise definition in the first place? When I see transition I usually first think of emission so I started working examples on my own to understand this R and P branches concepts but I couldn't match it with the definition.
I am disappointed by the physics literature and a loose way of defining things. Or could it be me? Am I missing something from my discussion here? It could be because of lack of sleep I am having these days but I am not seeing it.
Usually an IR spectral measurement will measure either an emission or absorption spectrum, but not both at the the same time. And usually I think it is an absorption spectrum. (A broadband source like a high temperature blackbody or an incadescent lamp is used, and the absorption spectrum of the gas is measured). I don't think an emission spectrum (arc discharge) gives much quality lines with an IR spectrum. ## \\ ## Meanwhile, I think there are also Raman measurements, where a visible monochromatic source (laser) is used and IR absorptions and emissions can cause shifts in the measured laser wavelength. With the Raman spectrum, both emission and absorption are measured simultaneously. If a diffraction grating spectrometer is used, the absolute wavelength of the shifted laser wavelengths are measured along with the unshifted laser wavelength. (Here I think is where double spectrometers sometimes become very useful. If the shifted wavelengths are weak compared to the unshifted signal, the first monochromator will eliminate most of the very intense unshifted signal, and the shifted signals can be more readily seen, measured at the exit slit of the second spectrometer).## \\ ## Additional note: If heterodyneing is employed by beating the shifted wavelength against the reference onto a photodiode, (works at r-f frequencies but not IR), then only the absolute value of the frequency shift is known, (detected as an r-f electrical signal at the shift frequency), but not the sign of the frequency shift.
@misko See edited additions to the above post.
Sorry I think you missed the point (and pain) of my post.
I am student, trying to understand rovibrational transitions from books and university lessons, not experimentalist working in a lab.
For a given spectrogram it must indeed be specified whether it's for absorption or emission, otherwise it may lead to confusion as you have noticed. In the book "Physics of Atoms and Molecules" by Bransden and Joachain figure 10.4 explicitly mentions that the associated picture is for absorption. Alternatively you can also see this link http://hyperphysics.phy-astr.gsu.edu/hbase/molecule/vibrot.html where the absorption spectrum of HCl is shown, the R branch is the right wing while the P branch is the left one.
Likes Charles Link
@misko Here is another "link" that I think gives a rather thorough presentation: https://www.physics.uoguelph.ca/~garrettp/teaching/PHY-1070/lecture-23.pdf See especially pp. 10,11, and 12.
Thank you guys.
I learned another way to think about this in the following video:
where they specify that "transitions where in the excited state J value is one unit greater than that of the lower energy state gives R lines, and in if they are one unit of J less than in the lower energy state they are P lines".
So basically if I take take the lower energy level as the reference point for calculating difference in J then I don't have to worry whether transition is absorption or emission.
Generally, at room temperature, many rotational states are thermally populated, but usually only the ground vibrational state is significantly thermally populated. Thus although Δv = ±1 are both allowed, only Δv = +1 (v = 0→1) really matters practically. However, accompanying this change in vibrational state, you can get rotational state changes of ΔJ = ±1, giving you the R and P branches.
Likes Charles Link
Related to P & Q branches confusion in rovibrational transitions + rant
1. What is the P & Q branch confusion in rovibrational transitions?
The P & Q branch confusion refers to the difficulty in distinguishing between the P and Q branches in rovibrational transitions of molecules. These branches correspond to transitions involving changes in rotational and vibrational energy levels, respectively. Due to the close spacing of these levels, it can be challenging to accurately assign transitions to the correct branch.
2. Why does the P & Q branch confusion occur?
The P & Q branch confusion occurs because of the nature of rovibrational transitions. These transitions involve both changes in rotational and vibrational energy levels, which are closely spaced. This makes it difficult to differentiate between the two branches, especially for molecules with a high rotational constant or low vibrational frequency.
3. How does the P & Q branch confusion affect spectroscopic analysis?
The P & Q branch confusion can affect spectroscopic analysis by leading to incorrect assignments of transitions and inaccurate determination of molecular properties. This is particularly problematic for high-resolution spectroscopy, where precise identification of spectral lines is crucial.
4. What techniques can be used to overcome the P & Q branch confusion?
Several techniques can be used to overcome the P & Q branch confusion, such as applying a magnetic field, using polarized light, or measuring the spectral lines at different temperatures. These methods can help to resolve the overlapping transitions and accurately assign them to the correct branch.
5. Why is the P & Q branch confusion a topic of frustration for scientists?
The P & Q branch confusion can be frustrating for scientists because it can lead to discrepancies in experimental data and hinder the understanding of molecular properties. It also requires careful analysis and advanced techniques to overcome, which can be time-consuming and challenging. This issue is particularly relevant in fields such as atmospheric and astrophysical spectroscopy, where precise measurements are crucial for understanding complex molecular systems.
  • Atomic and Condensed Matter
  • Other Physics Topics
