Packages acting on a conveyor belt
In summary, the static friction is maximum when the packages are about to slide, so you have##\hat t) W_t-Fr=0####W_t=Fr####W.sin(\alpha)=\mu N##From ##\hat n## we know that ##N=mg.cos(\alpha)-m.\omega ^2 .r##So we can replace with that##mg.sin(\alpha)=\mu (mg.cos(\alpha)-m.\omega ^2 .r)##
Like Tony Stark
179
Some packages of mass ##0.8 kg## are deposited on a conveyor belt, whose coefficient of static friction is ##0.4##. Determine:
A) The force exerted by the conveyor belt on each package a moment before and after passing by the point ##A##.
B) The angular coordinate in point ##B##, which is the point where the packages start to slide
C) The angular coordinate when the packages lose contact with the conveyor belt.
Newton's equations
A) Before passing by ##A## the forces acting are weight and normal force. Then, after passing by that point you have
(Tangential direction) ##W_t-Fr=m.a_t##
(Normal direction) ##-N+W_n=m.\omega ^2 .r##
Also, as the packages don't slide, we can say that ##a_t=0##
Are these ideas okay?
B) When the packages are about to slide, the static friction is maximum. So you have
##W_t=Fr##
The thing is that I don't have ##r## and I don't have ##\alpha##.
C) If they lose contact, then ##N=0## and
##\hat n) -N+W_n=m.\omega ^2 r##
##mg.cos(\alpha)=m.\omega ^2 r##
##cos(\alpha)=\frac{\omega ^2 r}{g}##
But I have the same problem that I had in ##B##.
For the first part of A, you are asked what force the belt exerts on each package, not what all the forces are on a package. You should answer in terms of the given mass.
For the second part of A, it is not clear what your answers are to the question asked.
For B, yes, you need to know r. Can you solve it algebraically, leaving r as an unknown? There is a trick to this, using the expansion of sin(x+y).
C is awkward. You have overlooked the fact that the package may be already sliding, increasing the angular velocity. I suspect this is more difficult than the questioner intended.
So for the first part of A) I should say that
##y) N-W=m.a_y##
##N-W=0##
##N=W##
##N=m.g##
##N=0.8*9.81##
Right?
For the second part of A, I wanted to say that if I want to calculate the forces exerted on the packages, you have to solve something similar to an inclined plane problem:
##\hat t) W_t-Fr=m.a_t##
##W_t-Fr=0##
##W_t=Fr##
##m.g.sin(\alpha)=0.4 N##
Where ##N## is an unknown normal force.
Then
##\hat n) -N+W_n=m.r.\omega ^2##
##-N+m.g.cos(\alpha)=m.r \omega ^2##
##N=mgcos(\alpha)-mr\omega ^2##
And then for C, do you mean that my answer is ok but I should take ##\omega## as a new unknown?
No, you are getting confused. In the second part of A it is still effectively horizontal. Your original equations were fine, but you did not turn them into an answer to the question asked.
for C, do you mean that my answer is ok but I should take ω as a new unknown?
In principle it is known, in the sense that it has a fixed relationship to the angle you are trying to find. Can you figure out what that relationship is? Consider energy (but I have not attempted this myself yet - will when I get a chance).
So the forces acting before and after the point A are the same?
No. As I wrote, what you had originally for the second part of A was correct:
(Tangential direction) Wt−Fr=m.at
(Normal direction) −N+Wn=m.ω2.r
Also, as the packages don't slide, we can say that at=0
All that is wrong is that you did not turn those into an actual answer to the question.
But in post #3 you introduced a variable α for the angle. This is unnecessary since it is vanishingly small.
Likes Like Tony Stark
So if I shouldn't introduce a variable for the angle, I shouldn't do any distinction between ##W_t## and ##W_n##. Then, the equations would be
##t) -Fr=m.a_t##
##n) N-P=m.w^2 .r##
##t) -Fr=m.a_t##
##n) N-P=m.w^2 .r##
Yes, where at=0 (as you wrote in post #1).
I notice you often use P without defining it. Is this standard in your course? I've not come across that convention. It seems to mean mg, right?
Sorry, "P" is for "Peso" ("Weight" in Spanish). I read some physics books written in Spanish and that's why I sometimes use "P" instead of "W". My bad
I tried to find the new ##\omega## considering energy. Firstly I said
##\frac{1}{2}mv_1^2+mgh_1=\frac{1}{2} mv_2^2 +mgh_2##
Where ##h_1## is the height of the straight part, ##h_2## the height at which the block falls and the different ##v## are the velocities in those positions. Also, ##v_2=\omega_2.r## and ##v_1=\omega_1 .r##
But I realized that there's friction, so the energy won't be conserved. The work done by the friction will be
##W=\frac{1}{2} m.(v_2-v_1)^2##
And now what should I do?
I tried something different. I said that ##x=sin (\alpha)## so ##\sqrt{1-x^2}=cos(\alpha)##
I had:
##mg.sin(\alpha)=\mu (mg.cos(\alpha)-m\omega ^2 .r)##
Now I have:
##mg.x=\mu (mg.\sqrt{1-x^2}-m\omega^2 .r)##
But I don't know how to solve it, or how to solve it with your method
I had:
Now I have:
Yes, you can solve it that way too. Rearrange your equation to get the surd (the square root term) on one side and all else on the other. Can you see how to get rid of the surd then?
With regard to part C, my energy idea does not work. Try to get the differential equation that applies once slipping has started. (I believe it cannot be solved.)
Related to Packages acting on a conveyor belt
1. What is a conveyor belt and how does it work?
A conveyor belt is a mechanical system used to transport materials or objects from one point to another. It consists of a continuous loop of rotating belts that move along a series of rollers or pulleys. The objects are placed on the belt and are carried along as the belt moves.
2. How do packages get sorted on a conveyor belt?
Packages on a conveyor belt are typically sorted using automated systems such as barcode scanners or sensors that detect the size and weight of the package. These systems then direct the packages to the appropriate destination based on predetermined criteria.
3. What are the benefits of using a conveyor belt for packages?
Using a conveyor belt for packages offers several benefits, including increased efficiency and productivity, reduced labor costs, and improved safety. It also allows for automated sorting and tracking of packages, which can help to prevent errors and delays.
4. How are packages protected on a conveyor belt?
Packages on a conveyor belt are typically protected by various safety features such as sensors, emergency stop buttons, and guards. These help to prevent damage to the packages and ensure the safety of workers operating the conveyor belt.
5. Can a conveyor belt handle different types of packages?
Yes, conveyor belts are designed to handle a wide range of package sizes, shapes, and weights. They can also be equipped with different types of attachments and accessories to accommodate specific types of packages, such as boxes, bags, or containers.
