Packing fraction of spheres in a HCC structure
In summary, the ratio of atomic sphere to unit cell volume in HCP (hexagonal close packing) is 0.74. This can be derived by considering a 1/6 of the HCP structure and calculating the volume of spheres within it, taking into account the three atoms in the middle layer of the structure. The height of the unit cell is twice the height of a tetrahedron made of the centers of four atoms, and the volume ratio is the volume of six atoms divided by the volume of the hexagon. Different choices of unit cell may result in the same answer, as long as the whole crystal can be covered by translations and the number of atoms is counted correctly.
CAF123
88
Show that the ratio of atomic sphere to unit cell volume in HCP (hexagonal close packing) is 0.74.
volumes of spheres, geometry
I did the same problem for FCC and BCC and it was fine.
My unit cell structure is that shown below. I labeled the height between the two hexagonal planes by ##h## and the length of the equilateral triangles comprising the hexagon by ##2r##. If we then consider a 1/6 of this structure in the obvious way and orient it suitably so that one of the sides of the lower triangles coincides with the x-axis say, then the volume of 1/6 of this structure is $$V = 2 \int_0^{r} \int_0^{\sqrt{3}x} \int_0^h dx dy dz = \sqrt{3}hr^2.$$ Multiply this by 6 to get the whole volume of the unit cell structure shown below.
I would like to try to relate the height of this structure to the radius ##r## of the spheres so that in the ratio, I get cancellation. I am assuming that the three spheres on the middle layer of the structure (labeled B in the sketch) are wholly contained within the structure?
Yes, for a closed packed structure there is a specific value for the ration between the height and the side of the hexagon. Imagine that you put some hard spheres in each node so that each one is in contact with nearest neighbors.
There is a definite relationship between ##h## and ##r## that you could either look up in your textbook, or derive it yourself (it's pretty easy).
Yes, if we look at just the hexagon shape and put six spheres at each of the nodes then each side of the hexagon has a length two times that of the radius of one of the spheres, which was my motivation for calling the length ##2r##. In the HCP structure, as seen from the diagram I posted, there are three atoms in the middle as well. It seems to me that these three atoms are wholly contained within the structure.
So would it be right that ##h = 2 (2r \cos 30^o) = 2 \sqrt{3} r## and so ##V = 6r^3##. As mentioned in the OP, this corresponds to 1/6 of the structure so the total volume is ##36r^3##.
So then I need to find the volumes of all the spheres inside the structure. Let ##v## be the volume of a sphere of radius ##r##. The three middle ones contribute ##3v##. The ones in the middle of the planar hexagons contribute ##(1/2)v##. And I figured that each of the spheres at the 12 nodes (6 per planar hexagon at the sides) contribute ##(1/6)v##. So the total volume I get is ##V' = 12((1/6)v) + 2((1/2)v) + 3v## which seems to give the wrong answer.
My reasoning for the nodal spheres was that we can neglect 1/2 of the volume each time (since exactly 1/2 of the sphere will be above the structure). Each node is in contact with two triangles so this is 1/3 of the amount making a full hexagon. Therefore the volume of a nodal sphere inside the structure is ##(1/2) (1/3) v##.
Adding up and taking the ratio I get about 0.70 which is close, but not quite right. Thanks.
I am thinking that I got my expression for ##h## incorrect, could you give me some pointers on that?
I can not quite follow your derivation. You are right that there are 6 whole spheres inside the unite cell.
The height of the cell is twice the height of a tetrahedron made of the centres of four atoms, so the sides of the tetrahedron is twice the radius. What is the height of a tetrahedron?
The volume ratio is the volume of six atoms divided by the volume of the hexagon.
ehild
Thanks ehild, I got the right answer ;) Just out of interest, I know the choice of unit cell is not unique so if I tried the question using a different unit cell (e.g perhaps just a sixth of the structure considered before) then I should get the same answer?
If it is really a unit cell, so as the whole crystal can be covered by its translations and you count the number of atoms in it correctly you have to get the same answer. We use a bigger and symmetrical unit cell instead of the smallest one (the primitive cell) because it is easier to see the symmetry and to count the number of atoms.
ehild
Likes CAF123
Thank you ehild.
Related to Packing fraction of spheres in a HCC structure
1. What is the packing fraction of spheres in a HCC structure?
The packing fraction of spheres in a HCC (hexagonal close-packed) structure is approximately 0.74. This means that about 74% of the available space is occupied by the spheres in the structure.
2. How is the packing fraction of spheres in a HCC structure calculated?
The packing fraction of spheres in a HCC structure is calculated by dividing the volume occupied by the spheres by the total volume of the unit cell. In the case of a HCC structure, the unit cell contains 6 spheres, so the calculation would be (6*4/3πr^3)/(a^3), where r is the radius of the spheres and a is the length of the unit cell edge.
3. How does the packing fraction of spheres in a HCC structure compare to other structures?
The packing fraction of spheres in a HCC structure is relatively high compared to other structures. For example, the packing fraction in a simple cubic structure is only 0.52, while in a face-centered cubic structure it is 0.74 and in a body-centered cubic structure it is 0.68.
4. What factors affect the packing fraction of spheres in a HCC structure?
The packing fraction of spheres in a HCC structure is primarily affected by the size of the spheres and the length of the unit cell edge. As the radius of the spheres increases, the packing fraction also increases. However, increasing the size of the unit cell without changing the size of the spheres can decrease the packing fraction. Additionally, the arrangement of the spheres within the unit cell can also affect the packing fraction.
5. What is the importance of the packing fraction of spheres in a HCC structure?
The packing fraction of spheres in a HCC structure is important for understanding the physical properties of materials. It can affect the strength, density, and other properties of materials. Additionally, it is a key factor in determining the efficiency of packing in various structures, which has implications in fields such as materials science and crystallography.
  • Atomic and Condensed Matter
  • Classical Physics
