- #36
jartsa
- 1,577
- 138
Q-reeus said:Not quite. As per earlier thread, considered as a tube of matter uniformly expanding axially, a local observer at some fixed radius from spin axis will be in a decreasing mass density region, and so redshift/clock-rate is changing. Locally perceived as increasing spin rate.
The picture I now have is of 'a spinning rocket accelerating in a snug guide tube', and expelled mass/gas now spins at the same rate as the rocket.
If my picture is accurate, yes to the extent relative velocity is nonrelativistic. Otherwise the situation is modulated by SR effects as per #28 - slower and continually slowing rotation for receding/broadside relative motion, speeding up within a narrowing angular range of approaching relative motion. You may find this link to other links interesting to follow: http://casa.colorado.edu/~ajsh/sr/srfs.html
How about if we consider a spinning, laser beams emitting disk, in a straight, light reflecting tube. Light that is emitted from the middle of the disk travels throuh the tube at speed of light. Light emitted from the rim of the disk travels through the tube slower than speed of light.
(the spinning axis and tube's symmetry axis are parallel, and all laser beams are parallel to tube's symmery axis when the laser sources are at rest)
The light going though the tube must carry angular momentum that's what's slowing it down.
Next thing to do here might be to replace lasers with electron guns ... then we might conclude that the electron population's spinning rate is unchanged when the electrons are accelerated by the electron guns ... But first we should agree about the laser light case.
