Parabola for 18 aluminum mirror
In summary, a parabola is a U-shaped mathematical curve that is used in the shape of an 18-inch aluminum mirror to focus light rays onto a single point. The mirror is made by shaping aluminum into a disc and then carefully curving its surface before being coated with reflective material. This type of mirror is commonly used in scientific research due to its large size and high reflectivity, but it can also be used in other fields such as manufacturing and construction. To maintain its accuracy and quality, regular cleaning, inspection, and proper storage and handling techniques are necessary.
jixon
Parabola for 18" aluminum mirror
Help; need to configure inputs into parabola formula to machine an 18" dia., 1.5"h aluminum disc. for use as primary objective mirror in telescope.
Astronomy news on Phys.org
Depends on the focal length. At f10 it little matters. What focal length do you have in mind?
Focal length 79.2", 0.256 in. @ apex; f/4.4
Using a CNC lathe but need inputs for autocad program to 'run' lathe for accurate cutting. Removing 32.53 cu. in. material.
Not sure what to plot for points along 'x' to perimeter from center, depth of 'y'
Related to Parabola for 18 aluminum mirror
1. What is a parabola and how is it related to an 18-inch aluminum mirror?
A parabola is a type of mathematical curve that is characterized by its shape, which resembles a U-shape. In the context of an 18-inch aluminum mirror, the parabola refers to the shape of the mirror's surface. The mirror is designed with a parabolic shape in order to focus light rays that hit its surface onto a single point, creating a clear and magnified image.
2. How is an 18-inch aluminum mirror made?
An 18-inch aluminum mirror is typically made by first shaping the aluminum into a flat circular disc. Then, using specialized tools and techniques, the surface of the disc is carefully shaped into a parabolic curve. Finally, the mirror is coated with a thin layer of reflective material, such as silver or aluminum, to enhance its reflective properties.
3. What makes an 18-inch aluminum mirror a good choice for scientific research?
An 18-inch aluminum mirror is an excellent choice for scientific research due to its large size and high reflective properties. The large size allows for a wider range of light to be captured, making it ideal for studying distant objects in space. The high reflectivity of the aluminum coating also ensures that a clear and accurate image is produced, making it useful for various scientific applications.
4. Can an 18-inch aluminum mirror be used in other fields besides science?
Yes, an 18-inch aluminum mirror can also be used in other fields besides science. For example, it is commonly used in the manufacturing of telescopes, cameras, and other optical instruments. It can also be used in the automotive industry for headlights and in the construction industry for reflective surfaces on buildings.
5. How do scientists maintain the accuracy and quality of an 18-inch aluminum mirror?
To maintain the accuracy and quality of an 18-inch aluminum mirror, scientists must regularly clean and inspect the mirror's surface for any scratches or damage. They must also ensure that the mirror is properly aligned and mounted in its frame to prevent distortion. Additionally, proper storage and handling techniques must be followed to avoid any damage to the reflective coating.
