MHB Parabola standard form of equation at x = -5
To find the standard form of the parabola with a vertex at the origin and passing through the point (-5, 1/8), the equation can be expressed as y = ax^2. By substituting the point into the equation, it is determined that a = 1/200, leading to the final equation y = (1/200)x^2. The discussion clarifies the correct approach to solving the problem and confirms the use of the vertical parabola formula. The solution is validated, ensuring the parameters and characteristics align with the given conditions.
Joystar77
Find the standard form of the equation of the parabola with the given characteristics and vertex at the origin. Passes through the point (-5, 1/8); vertical axis.
I know that there is no focus of the parabola or equation given for this problem, so how would I solve this problem? Is the correct formula to use the following?:
x^2= 4py
Are these the correct steps to take?
1. Write original equation
2. Divide each side by number given.
3. Write in standard form.
Mathematics news on Phys.org
re: Parabola standard form of equation at x=-5
I have two different formulas for using the conic section of a parabola, can someone please tell me which is correct for this type of problem?
The first one is as follows:
Type: Parabola
General Equation: y = a (x-h)^2 + k
Standard Form: (x - h) ^2 = 4p (y-k)
Notation:
1. x2 term and y1 term.
2. (h,k) is vertex.
3. (h, k does not equal p) is center of focus, where p = 1/4a.
4. y =k does not equal p is directrix equation, where p = 1/4a.
Value:
1. a >0, then opens up.
2. a < 0, then opens down.
3. x = h is equation of line of symmetry.
4. Larger [a] = thinner parabola; smaller [a] = fatter parabola.
Type: Parabola
General Equation: x = a (y-k)^2 + h
Standard Form: (y-k)^2 = 4p(x-h)
Notation:
1. x1 term and y2 term.
2. (h,k) is vertex.
3. (h does not equal p, k) is focus, where p = 1/4a.
4. x = h does not equal p is directrix equation, where p = 1/4a.
Values:
1. a > 0, then opens right.
2. a < 0, then opens left.
3. y = k is equation of line of symmetry.
In this problem, find the standard form of the equation of the parabola with the given characteristics and vertex at the origin. Passes through the point (-5, 1/8); vertical axis. Would this problem be correct if I work it out this way?
The axis is vertical so I know that the vertex is (0,0).
y = a (x - h)^2 + k
Since, I know that the vertex is at (0,0), then I know that h = k = 0 and thought that this would be the proper way to work the problem out.
y = ax ^2
1/8 = 25a
a = 1/200
so, y = 1/200 x ^2
Is this correct way to work out this problem? If not, then can somebody please help me? I am a little confused on which formula to use for this problem.
Re: Parabola standard form of equation at x=-5
Personally, I would just look at the fact that the vertex is at the origin, which means, given the vertical axis of symmetry, that the parabola must be of the form:
$$y=ax^2$$
Now, using the other given point, can you determine the value of the parameter $a$?
What do you mean by parameter? Isn't the value of a = 1/200?
$$y=ax^2$$
In this context, you can think of a parameter as a constant whose value we must determine. We are told the parabola passes through the point $$(x,y)=\left(-5,\frac{1}{8} \right)$$. And so you are right, we find:
$$\frac{1}{8}=a(-5)^2=25a\implies a=\frac{1}{200}$$
And so we know the parabola satisfying the given conditions is:
$$y=\frac{x^2}{200}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
