MHB Parabolic 2. order partial differential equation
mathmari
MHB
Hey! :o
I have to find the Normal form of the 2.order partial differential equation. I am not sure if my solution is correct..
The differential equation is:
$ u_{xx}-4u_{xy}+4_{yy}-6u_x+12u_y-9u=0$
$a=1, b=-2, c=4$
$b^2-ac=4-4=0 \Rightarrow $ parabolic
$\frac{dy}{dx}=\frac{1}{a}(b \pm \sqrt{b^2-ac})$
$\frac{dy}{dx}=-2 \Rightarrow dy=-2dx \Rightarrow y=-2x+c \Rightarrow \xi=y+2x$
To find $ \eta$ ,we know that the determinant of the Jacobi-Matrix should be different from $0$ .
$J=\begin{vmatrix}
\xi_x & \xi_y\\
\eta_x & \eta_y
\end{vmatrix}=\xi_x \eta_y-\xi_y \eta_x \neq 0$
$ 2 \eta_y-n_x \neq 0$
So we could take $\eta=y$, couldn't we?
In this case it is $ 2 \neq 0$.
$\partial_x=2\partial_{\xi}$
$\partial_y=\partial_{\xi}+\partial_{\eta}$
$\partial_{xx}=4\partial_{\xi \xi}$
$\partial_{yy}=\partial_{\xi \xi}+2 \partial_{\xi \eta}+\partial_{\eta \eta}$
$\partial_{xy}=2\partial_{\xi \xi}+2 \partial_{\xi \eta}$
By replacing this in the differential equation we have:
$u_{\eta \eta}+3u_{\eta}-\frac{9}{4}u=0$
Could you tell me if my result is correct?
Shouldn't it be in the form $ u_{\xi \xi}=f(u,u_{\xi}, u_{\eta})$ ?
My result is in the form $ u_{\eta \eta}=f(u,u_{\xi}, u_{\eta})$.. (Thinking)
mathmari said:
Hey! :o
$a=1, b=-2, c=4$
$J=\begin{vmatrix}
\xi_x & \xi_y\\
\eta_x & \eta_y
Hey!
The calculations look good. :)
But I think you should assign the constant equation to the 2nd variable $\eta$.
As a result $\eta = C$ will correspond to the tangent line.
Consider that for a regular upright parabola $y=x^2$ the tangent line at the top is $y=0$.
You might use for instance:
\begin{cases}
\xi = x \\
\eta = 2x + y
\end{cases}
\begin{cases}
\xi = x \\
\eta = 2x + y
\end{cases}
Using \begin{cases}
\xi = x \\
\eta = 2x + y
\end{cases} I found the following:$\partial_x=\partial_{\xi}+2 \partial_{\eta}$
$\partial_y=\partial_{\eta}$
$\partial_{xx}=\partial_{\xi \xi}+4 \partial_{\xi \eta} +4 \partial_{\eta \eta}$
$\partial_{yy}=\partial_{\eta \eta}$
$\partial_{xy}=\partial_{\xi \eta}+2 \partial_{\eta \eta}$
So substituting these at the differential equation we get:
$$u_{\xi \xi}-6u_{\xi}-9u=0$$
That is the form that it should be! (Yes)
Thank you for your help! (Smirk)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
