Parabolic Photovoltaic Solar Tower
In summary, the conversation revolves around designing a Parabolic photovoltaic solar tower for a school project. The individual is seeking help with mirror angles and PV collector chip placement, as well as using a Non-Imaging Fresnel lens to concentrate sunlight on the collectors. They hope to build a small scale model capable of powering one 110v electrical outlet within 5 weeks. Questions are raised regarding the maximum light power flux density, maximum rated junction temperature, heat sinking arrangement, and thermal resistance. The individual is also advised to calculate the maximum concentration ratio of the lensing system and is informed about the typical usage of thermal-based conversion and high concentration ratios in solar converters.
Solarguy
I am attempting to design my own Parabolic photovoltaic solar tower for a school project. I am working on numbers at the moment, but any helpful Ideas about mirror angles or Pv collector chip placement would really be great. Also I plan on using a shaped Non-Imaging Fresnel lens to help concentrate the sunlight on my collectors. I hope to be able to build a small scale model which would be capable of powering one 110v electrical outlet. I only have 5 weeks to design and build this model so any helpful suggestions would be appreciated.
What is the maximum light power flux density that your solar cells will be able to withstand? Like, what is their maximum rated junction temperature, and how are you heat sinking them? What is the thermal resistance of your heat sinking arrangement?
With the above info, you can calculate the maximum concentration ratio of your lensing system. Most of the concentration-based solar converters that I've seen use thermal-based conversion and a high concentration ratio. If you're going to use solar cells for the conversion, I would guess that the maximum concentration ratio would be like 4x or so? Maybe more with very effective heat sinking...
Hello there,
Designing a Parabolic photovoltaic solar tower for a school project is a great idea! It is always exciting to see students taking an interest in renewable energy and sustainable solutions. As for your questions about mirror angles and PV collector chip placement, there are a few factors to consider.
Firstly, the angle of the mirrors should be optimized to capture the most sunlight possible throughout the day. This means that the mirrors should be adjustable to track the movement of the sun. A good starting point would be to set the mirrors at a 45-degree angle, but you may need to adjust this based on your location and the season.
Secondly, the placement of the PV collector chips is also important. They should be positioned at the focal point of the parabolic reflectors to receive the most concentrated sunlight. You may need to do some calculations to determine the exact placement, but a general rule of thumb is to place the collector chips at the center of the parabolic curve.
Using a shaped Non-Imaging Fresnel lens is a great idea to help concentrate the sunlight even further. Just make sure to properly align the lens with the parabolic reflectors to maximize its effectiveness.
In terms of building a small-scale model that can power one 110v electrical outlet, it is definitely doable. However, it will require careful planning and efficient design. You may want to consider using high-efficiency PV collector chips and optimizing the angle and placement of the mirrors to maximize the energy output.
Lastly, with only 5 weeks to design and build your model, it is important to stay organized and prioritize your tasks. Make sure to do thorough research and plan out your design before starting the construction process. Also, don't hesitate to seek help from your teachers or other experts in the field if you encounter any challenges.
I wish you all the best in your project and hope that it inspires you to continue exploring renewable energy solutions in the future. Good luck!
FAQ: Parabolic Photovoltaic Solar Tower
1. What is a Parabolic Photovoltaic Solar Tower?
A Parabolic Photovoltaic Solar Tower is a type of solar power plant that uses parabolic mirrors to concentrate sunlight onto a central tower. The tower contains photovoltaic cells that convert the concentrated sunlight into electricity.
2. How does a Parabolic Photovoltaic Solar Tower work?
The parabolic mirrors in a Parabolic Photovoltaic Solar Tower are designed to track the movement of the sun throughout the day. They reflect and concentrate sunlight onto a receiver at the top of the tower, which then heats up a fluid that produces steam to power a turbine and generate electricity.
3. What are the advantages of a Parabolic Photovoltaic Solar Tower?
One advantage of a Parabolic Photovoltaic Solar Tower is its high efficiency in converting sunlight into electricity. The concentrated sunlight allows for more efficient use of photovoltaic cells. Additionally, the tower design allows for continuous energy production, even after sunset, due to the thermal storage of the heated fluid.
4. What are the limitations of a Parabolic Photovoltaic Solar Tower?
One limitation of a Parabolic Photovoltaic Solar Tower is its high cost of construction. The complex design and materials needed for the parabolic mirrors and tower can be expensive. Additionally, the tower must be placed in areas with high levels of sunlight, limiting its potential locations.
5. How does a Parabolic Photovoltaic Solar Tower compare to other solar power technologies?
Compared to other solar power technologies, a Parabolic Photovoltaic Solar Tower has a higher efficiency and capacity for energy production. Additionally, its thermal storage allows for continuous energy generation, making it a more reliable energy source. However, it also has a higher cost of construction and is limited to areas with high levels of sunlight.
