Parabolic Trajectory Of Water Stream
If you have not yet started, can you show me what you already know about the problem?In summary, the equation y = -0.003x^2 + 0.58x + 3 can be used to model the stream of water from a water hose, where x and y represent the distance in feet. A firefighter holding the hose 3 feet above the ground and 137 feet from a building is trying to determine if the stream of water will pass through a window located 26 feet above the ground. To solve this word problem, it is necessary to analyze the graph and plug in the given values to see if the resulting y-value is greater than 26, indicating that the water will pass through the window.
username877
A stream of water from a water hose can be modeled by the graph of y= -0.003x^{2}+0.58x+3 where x and y are measured in feet. a firefighter is holding the hose 3 feet above the ground, 137 feet from a building. will the stream of water pass through a window if the top of the window is 26 feet above the ground?
really need help.
Mathematics news on Phys.org
Re: How to solve word problem
Hello and welcome to MHB! :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
