geoffrey159
- 535
- 72
During World War II the Russians, lacking sufficient
parachutes for airborne operations, occasionally dropped soldiers
inside bales of hay onto snow.
The human body can survive an average pressure on impact of
30 lb/in2 . Suppose that the lead plane drops a dummy bale equal
in weight to a loaded one from an altitude of 150 ft, and that the
pilot observes that it sinks about 2 ft into the snow. If the weight of
an average soldier is 144 lb and his effective area is 5 ft2 , is it safe
to drop the men?
energy conservation
For clarity, I set h1 = 150ft, h2 = 2ft, mg = 144lb, and S = 5lb/ft^2.
Using conservation of energy, the paratrooper's speed just before impact is ##v_i = \sqrt{2gh_1}##.
If ## E_r## is the mechanical energy once the paratrooper is at rest 2ft under snow, ##E_i## the mechanical energy at impact, and ##\vec N## the force of snow on man, then:
\left\{
\begin{array}{}
E_r = 0\\
E_i = mg (h_1+h_2) \\
E_r - E_i = \int_{\vec r_{impact}}^{\vec r_{rest}} \vec N.d\vec r
\end{array}
\right.
And, because the force of the snow is vertical,
## mg(h_1+h_2) = \int_{0}^{h_2} N(y) dy \approx h_2 N_{av} ##
So the average pressure the paratrooper must resist is
##\frac{N_{av}}{S} = 144*152/(2*5) \ lb/ft^2 = 152/(2*5) \ lb/in^2 = 15.2 \ lb/in^2 < 30 \ lb/in^2##
So yes it is 'safe' (non lethal). Is it correct ?
