Parachutist's fall is because of balanced force or unbalanced force?
  • Thread starter inqstudent
  • Tags
    Fall Force
In summary, a parachutist's fall is caused by the Earth's gravity, which initially has no opposing force. As the air resistance increases, it acts against gravity until the forces are balanced and the velocity remains constant. When the parachute opens, the air resistance significantly increases, causing the parachutist to accelerate upwards and the velocity to decrease until it reaches a constant value known as terminal velocity. This is due to the opposing forces of gravity and air resistance being equal, resulting in a net force of 0 N. The parachutist's movement can be explained by Newton's 1st law of motion, which states that an object will continue to move at a constant velocity unless acted upon by an unbalanced force. The velocity of
inqstudent
A parachutist's fall is due to gravity of the Earth which pulls down the weight of the parachutist towards it. Initially there is no air resistance. The air resistance increases and acts against gravity. There is a phase the velocity is constant. When parachute opens, air resistance increases significantly and the parachutist accelerates upwards and velocity decreases until they balance. My question is that if the forces were balanced, the Air Resistance= Gravity and net force on the parachutist is 0 N, how come does the Parachutist move?
http://astarmathsandphysics.com/gcse-physics-notes/gcse-physics-notes-the-motion-of-a-parachutist.html
Try applying Newton's 1st law of motion to the parachutist at the moment when the two opposing forces equalise.
And welcome to PF, by the way!
:cool: Thank you Bandersnatch but here do you mean to say that the object moves at a constant velocity of 9.8 m s-1 irrespective of the acceleration, which is 0.
As the 1st law says, the object will move at whatever velocity it has, unless an unbalanced force acts on it.
If the net force is 0, the acceleration will be 0.
So, an object moves at a constant velocity not "irrespective of acceleration" but because the acceleration is 0.
What is the velocity a falling object will have when the air drag force becomes equal to the gravitational force?(clue: it's mentioned on the graph in your link)
do you know about viscosity?
force experienced by a body with radius 'r' traveling through a fluid of viscosity 'η' with speed 'v' is
F=6∏ηrv
body moves with a constant velocity called terminal velocity 'V' when external force (weight in this case) equals viscous force
so, 6∏ηrV=mg
V=mg/6∏ηr
air is also a fluid and has viscosity
viscous force is directly proportional to radius and velocity
if radius is large velocity will be small and vise versa
so all bodies will fall with a specific velocity unless its density is smaller than air like hydrogen
Likes 1 person
Bandersnatch Before the parachute opens its 50 m s-1 and after it open its 5 m s-1 according to the graph.
before the parachute opens radius of cross section is small (of man).so velocity is large .
after it opens radius increases,so velocity decreases
Thank You very much... I understood it finally, @basheer uddin and @bandersnatch... can you please telp me how to tag users in a reply?
Yes, it's called terminal velocity. It's different before and after, because the drag force is different - which is basically what basheer uddin is saying.
At those two velocities the acceleration is 0 and the Newton's 1st law applies.
edit: do you mean how to quote posts? There's a "quote" button in the lower-right corner of each post. The "M" button next to it let's you quote multiple posts.
Likes 1 person
FAQ: Parachutist's fall is because of balanced force or unbalanced force?
What is the difference between balanced and unbalanced forces?
Balanced forces are equal in magnitude and opposite in direction, resulting in no change in motion. Unbalanced forces are not equal, causing a change in motion.
Which type of force causes a parachutist's fall?
The parachutist's fall is caused by unbalanced forces. The force of gravity is greater than the force of air resistance, resulting in a downward acceleration.
How does the size and shape of a parachute affect the balance of forces?
A larger and more air-resistant parachute will create more balanced forces, slowing the parachutist's fall. A smaller and less air-resistant parachute will create less balanced forces, resulting in a faster fall.
Can a parachutist's fall ever be caused by balanced forces?
No, a parachutist's fall is always caused by unbalanced forces. In order for a parachutist to reach a state of balanced forces, they would need to reach terminal velocity, where air resistance equals the force of gravity.
What is the role of air resistance in a parachutist's fall?
Air resistance plays a crucial role in a parachutist's fall. As the parachutist falls, air resistance increases until it becomes equal to the force of gravity, resulting in a constant velocity known as terminal velocity.
9K
