Paradox in calculating potential of a sphere
In summary, the conversation discusses finding the electrostatic potential of a solid sphere with a reference point of 0 statvolt at infinite. The potential energy of the sphere is calculated using the equation U = (1/2) ∫ρφdv and differentiated to get the potential φ = 2Q/5r. However, it is pointed out that this contradicts the expected potential of Q/r for a solid sphere. It is suggested to consider the distribution of charge and use Gauss' law to calculate the electric field inside and outside the sphere. Further explanation is given on how to calculate the voltage from infinity to the outside and from the outside to the inside of the sphere. A resource is provided for reference.
Buffu
849
146
Find electrostatic potential of a solid sphere with reference point of 0 statvolt at infinite.
Potential energy of a solid sphere is ##\dfrac35 \dfrac{Q^2}{r}##.
And I know ##\displaystyle U = {1\over 2} \int \rho \phi dv##.
So ##2\dfrac {dU}{dv} = \dfrac{dU}{dr}\cdot\dfrac{dr}{dv} = \rho \phi##
Differentiating the sides and then plugging for ##\displaystyle \rho = {3Q \over 4\pi r^3 }##
I got ##\phi = \dfrac{2Q}{5r}##.
But electrostatic potential is ##\displaystyle Q \over r## for a solid sphere.
Why is this paradox ? what I am missing ?
How is the charge distributed in your sphere?
The potential of what, where, with which type of charge distribution?
Start with the volume outside the sphere. It is way easier than the calculation you did.
Buffu said:
Potential energy of a solid sphere is 35Q2r35Q2r\dfrac35 \dfrac{Q^2}{r}.
I do not agree with this. For a conducting metal sphere, the potential energy (with respect to [itex]\infty[/itex]) is [tex]U=-W=-\int_\infty^a\vec{F}\cdot d\vec{\ell}[/tex] where [itex]\vec{F}[/itex] is the Coulomb force (the Coulomb force is the electrostatic force due to a single point charge at the origin or a sphere centered at the origin outside the sphere). From this, you could get voltage.
However, there is an easier way. We know that the electric field of a solid conducting sphere outside of the sphere (i.e., for [itex]r>a[/itex]) is [tex]\vec{E}=\frac{1}{4\pi\epsilon_0}\frac{Q}{r^2} \, \hat{r}[/tex] where [itex]Q[/itex] is the charge enclosed by the sphere and [itex]r[/itex] is the radial distance away from the center of the sphere. Voltage is [tex]V=-\int_\infty^a\vec{E}\cdot d\vec{\ell}[/tex]
Edit: this applies to uniformly distributed charge. The comment @mfb made about the distribution of the charge is relevant.
I don't think the sphere is conducting.
Uniformly distributed.
I am also a bit confused as to what and where.
Original statement :-
Find the potential of a solid sphere as a function of ##a##. For ##a < r## and ##a > r##.
There was image showing what is ##a##, that I can't post :(. But I can explain what ##a## is.
It is the radius vector from the centre of the sphere to a location in space, something like what is "R" in spherical coordinates.
Sorry.
Sorry.
As long as the charge is uniformly distributed on the surface of the insulating sphere and there is no external electric field, my explanation will still apply outside of the sphere.
Inside the sphere, you need to apply Gauss' law to get the electric field. Recall that the charge enclosed is going to depend on the radius of your Gaussian surface. Once you have that electric field, use [tex]V_{in}=-\int_\infty^R\vec{E}_{out}\cdot d\vec{\ell}-\int_R^0\vec{E}_{in}\cdot d\vec{\ell}[/tex] This is the voltage from infinity to the outside of the sphere using the electric field outside the sphere plus the voltage from the outside of the sphere to the inside of the sphere using the electric field inside the sphere. I'm using [itex]R[/itex] for the radius of the sphere rather than [itex]a[/itex] since you seem to be using [itex]a[/itex] for the radial coordinate.
Likes Buffu
I get what you are saying but why I am wrong is the main question.
I think I am wrong in saying ##3 Q^2/(5R)## as you said in your first post but see http://farside.ph.utexas.edu/teaching/em/lectures/node56.html (line 601). It agrees with my proposition.
Be careful which formula you take from where. What the author is calculating there is the energy needed to form such a sphere from an initial state where the charge has a large separation. Your problem asks for something completely different - the electrostatic potential as function of the position.
To clarify, I really should have said [tex]V_{in}=-\int_\infty^R\vec{E}_{out}\cdot d\vec{\ell}-\int_R^r\vec{E}_{in}\cdot d\vec{\ell}[/tex] where [itex]r<R[/itex] is some radius inside the sphere. Letting [itex]r=R[/itex] gives you the self energy like @mfb said, which isn't really what you want.
But right hand side of ##\displaystyle U = {1\over 2} \int \rho \phi dv## has self energy term, so I thought I just need to put my value in it.
When I am allowed to use this equation to get ##\phi## by differentiating ? or I am not allowed to do so.
=> don't use it, unless you want to calculate the self-energy.
Likes Buffu
Why ? It looks like a normal integral to me.
Yes, but the integral has nothing to do with the question you try to answer here.
##\displaystyle \int \rho \phi dv## has a potential term. what does it mean here ??
mgh is a potential term as well. Not every potential that exists in physics is relevant for your problem.
The problem is way easier than your approaches here.
No I did not pick a "potential integral" from anywhere. ##\phi## here is Electrostatic potential not any potential in physics.
I want to know why this approach is wrong more than how to solve this.
Read the link you submitted in Post #6. Φ(r) is the potential on the surface of a sphere of radius r with homogeneous charge distribution. The sphere is surrounded with vacuum. You use this Φ to calculate the work needed to "fill" a sphere of radius R with charge. But you have to determine the potential inside and outside of a homogeneously charged sphere of radius R. They are different.
Likes Buffu
So If I were to determine potential on the surface of sphere, then I can differentiate and get the potential, like I did in original post.
No. The potential in the integral is not the same as the potential of the final charged sphere.
The other thing, it is a volume integral, for a closed volume. You can not differentiate with respect to the volume.
You are correct I can't differentiate wrt volume.
FAQ: Paradox in calculating potential of a sphere
What is a paradox in calculating potential of a sphere?
A paradox in calculating potential of a sphere refers to the contradicting results obtained when trying to determine the electric potential at different points on the surface of a charged sphere. This is due to the infinite number of points on the surface and the varying distance between them and the center of the sphere.
Why is it difficult to calculate the potential of a sphere?
Calculating the potential of a charged sphere can be difficult because of the infinite number of points on its surface and the varying distance between them and the center of the sphere. This makes it challenging to accurately determine the electric potential at each point.
What factors affect the potential of a sphere?
The potential of a sphere is affected by the amount of charge it has, the distance between the charges, and the distribution of the charges on the surface of the sphere. These factors can lead to differing potential values at different points on the surface.
Can the potential of a sphere be calculated accurately?
Although calculating the potential of a sphere can be challenging due to its complex nature, it is possible to obtain accurate results through mathematical approximations and numerical methods.
How is a paradox in calculating potential of a sphere resolved?
To resolve the paradox, the sphere is typically divided into smaller sections, and the potential at each point is calculated using more precise methods such as calculus or numerical integration. These calculations can then be combined to obtain an accurate overall potential for the sphere.
