Parallel electrodes (space charge density, current density)
In summary, the author is having difficulty solving a problem involving dielectrics. They try to solve for the space charge density by relating current and space charge density, but run into a time dependence issue. They try to solve for the space charge density by relating current and space charge density, but run into a time dependence issue.
deedsy
81
Two plane parallel electrodes are separated by a plate of thickness s whose conductivity [itex] \sigma [/itex] varies linearly from [itex] \sigma_0 [/itex] near the positive plate to [itex] \sigma_0 + a [/itex] near the negative plate.
Calculate the space charge density [itex] \rho_f [/itex] when the current density is [itex] J_f [/itex].
*see below
I am having a tough time with this problem. Here's what I've been trying.
the conductivity varies linearly, so setting the two plates at z=0 and z=s, [itex] \sigma = \sigma_0 + \frac{az}{s} [/itex]. I believe that gives me the correct conductivity anywhere between the plates.
Now, I tried to relate the current density and the space charge density by trying to implement the conservation of charge equation [itex] \nabla \cdot \vec J_f = -\frac{\partial \rho_f}{\partial t} [/itex], but wasn't getting anywhere.
I can't just sub in [itex] J_f = \sigma E = (\sigma_0 + \frac{az}{s}) E [/itex] can I? And then get an expression for the varying electric field between the plates, and plug that in. Even if I was able to modify Ohm's Law for this material, I would still have a time dependence on the space charge density term, and I know that can't be right...
the 2nd part of the question wants you to plug in numbers (to the equation derived in this part) to calculate the space charge density. They give you [itex] \epsilon_r, J_f, s[/itex] and the two conductivities (so nothing about time).
So now I'm more confused because [itex] \epsilon_r [/itex] is what we learned when dealing with dielectrics, but the material inserted has a conductivity...
Does anyone have an idea how I could proceed with this problem - was I even on the right track?
Good so far.
You have a time-dependence in your expression. In equilibrium (!), how does the charge density depend on time?
mfb said:
Good so far.
well my thinking is in equilibrium, no charges are moving so [itex] \frac{\partial \rho_f}{\partial t} = 0[/itex] so it is constant.
But [itex]\rho_f [/itex] is what I need to solve for, so I wouldn't want to eliminate it from my equation..
I'm going to sleep on it for now
The charge density will re-appear elsewhere, once you have the electric field as function of the position.
ok, so I couldn't see any other way on how to involve [itex]\epsilon_r [/itex] other than assuming the material is a class A dielectric...(even though it has a conductivity, which I thought was not possible). Here's what happened when I assumed this:
Creating a gaussian cylinder from one plate up into the space density region..
[itex] \oint \vec{D} \cdot d\vec{a} = DA = \sigma_f A + \rho_f A z [/itex]
[itex] D = \sigma_f + \rho_f z [/itex]
[itex] \vec{D} = \epsilon_0 \epsilon_r \vec{E} [/itex]
[itex] \vec{E} = \frac{\sigma_f}{\epsilon_0 \epsilon_r} + \frac{\rho_f z}{\epsilon_0 \epsilon_r} [/itex]
So if my assumptions are right, I could then plug this E (along with my varying conductivity expression) into my conservation of charge equation, giving me an expression relating [itex]J_f [/itex] and [itex]\rho_f [/itex]:
[itex] \nabla \cdot \vec{J_f} = \nabla \cdot [(\sigma_0 + \frac{az}{s})(\frac{\sigma_f}{\epsilon_0 \epsilon_r} + \frac{\rho_f z}{\epsilon_0 \epsilon_r})] =0[/itex]
This is the only way I could think of how to solve for the E-field (using dielectrics equations, even though I'm not sure they apply here..).
Looks fine.
E depends on z -> D depends on z -> between z and z+dz you need some charge -> charge density depends on derivative of D.
mfb said:
Looks fine.
good, thanks a lot for your help. But I'm still having an issue...
when I solve the expression for [itex] \rho_f[/itex] I get:
[itex]\rho_f = (\frac{1}{\sigma_0 z + \frac{az^2}{s}}) (J_f \epsilon_0 \epsilon_r - \sigma_0 \sigma_f - \frac{az^2 \sigma_f}{s}) [/itex]
There's a couple issues with this:
-The space charge density is infinite at z=0 (on the surface of one of the plates)
-The book wants you to calculate [itex] \rho_f[/itex] given [itex] J_f, \sigma_0, a, s [/itex] and [itex]\epsilon_r [/itex], so they don't give [itex]\sigma_f [/itex] like I have in my expression..
But if you think my process looks okay, I'll just ask my professor in a couple days. Maybe there's a trick or something.
Then take a surface outside those plates, or avoid the plates completely. This looks like a pure calculation problem. Actually, your formulas look more complicated than I would expect.
What is ##\sigma_f##?
the charge density on the plates.
Even if I ignore this charge density, i run into the same problem (division by 0 at z=0).
The only thing I'm not confident about now is my expression for E; I've never calculated/seen an example of how to calculate E in a varying conductive material, and like i said, the only time I've used the relative permittivity was working with dielectrics, so I don't know how else to bring it into my expression
Why can't you solve this for E to get E as a function of z? (Maybe I'm missing something.)
Once you have E(z), you can calculate ∇⋅E.
Likes deedsy
wow, yeah that makes sense to me!
but why would they give me the relative permittivity [itex] \epsilon_r [/itex]?
Since [itex] \nabla \cdot \vec{E}= \frac{\rho}{\epsilon_0}[/itex] , am I just supposed to add the relative permittivity to this equation? Is that even legal?
yeah I think it's okay to do that
##\vec{\nabla} \cdot \vec{E} = \frac{\rho_f + \rho_b}{\varepsilon_0} = \frac{\rho_f}{\varepsilon_r \varepsilon_0}## for a linear dielectric where ##\varepsilon_r## does not depend on position. (##\rho_b = ##bound charge density.)
yep! thanks TSny. I guess (non perfect) dielectrics are allowed to have a conductivity
Related to Parallel electrodes (space charge density, current density)
1. What is the concept of parallel electrodes?
Parallel electrodes refer to a set of two or more conductive plates or surfaces that are placed parallel to each other. These electrodes are used in various scientific experiments and devices, such as capacitors, batteries, and electrochemical cells.
2. How is space charge density related to parallel electrodes?
Space charge density is a measure of the amount of electric charge per unit volume in a given space. In the case of parallel electrodes, the space charge density is affected by the distance between the electrodes, the material of the electrodes, and the potential difference applied between them.
3. What is the significance of current density in parallel electrodes?
Current density is a measure of the amount of electric current flowing through a given area. In parallel electrodes, the current density is directly related to the space charge density and the potential difference between the electrodes. It can also be affected by the material and geometry of the electrodes.
4. How does the distance between parallel electrodes affect the space charge density and current density?
The distance between parallel electrodes has a significant impact on the space charge density and current density. As the distance decreases, the electric field between the electrodes increases, leading to a higher space charge density and current density. Conversely, increasing the distance decreases these values.
5. What factors can influence the space charge density and current density in parallel electrodes?
The space charge density and current density in parallel electrodes can be influenced by various factors, including the distance between electrodes, the material and geometry of the electrodes, and the potential difference applied between them. Other factors, such as temperature, can also affect these values in some cases.
9K
