Parallel LCR resonant frequency derivation for larger resistances
In summary, the conversation discusses deriving an expression for the resonant frequency of a parallel LCR circuit with a large resistance, with the help of complex numbers. The first step is found to be correct, and the method of finding the resonant frequency by calculating the impedance directly is mentioned as well. The conversation also discusses using complex numbers to solve the second order differential equation and finding the poles of the transfer function in extended Fourier space.
QuarterWit
[SOLVED] Parallel LCR resonant frequency derivation for larger resistances
There have been similar questions here before which I have seen, but I couldn't find an answer with the detail I require.
I would like to derive an expression for the resonant frequency of a parallel LCR circuit with a large (not negligible) resistance.
I have seen a https://www.physicsforums.com/showthread.php?t=121069" of a solution (the same as mine but with the "4" omitted) but it doesn't fit my experimental data by a long shot, though my data could be wrong. The solution I came up with is a lot closer to my data but that doesn't necessarily mean it's right, could someone check through and explain if/where I've gone wrong
http://gray.slightlybeanish.com/Other/LCR.jpg
http://gray.slightlybeanish.com/Other/LCRDerivation.jpg
I mostly suspect the first step is wrong, I was trying to apply Kirchoff's law
QuarterWit said:
... an expression for the resonant frequency of ...
I[/URL] agree with this. You just have to make sure that 1/LC > R2/4L2 (otherwise the system is overdamped).
Kirchoof is never wrong. What you have done is right. If you want to get the solution of the equation by the help of complex numbers. However that is unnecessary
Thanks for replying so quickly, I'm glad you agree.
Fedex: I'm not sure whether you mean your 3rd sentence to be connected to the 2nd or the 4th. Anyway, I have used complex numbers, which is why the arguments under the square root changed signs.
As turin said, I'd assumed 1/LC > R2/4L2. Which would give a complex solution to the quadratic, leading to an oscillating solution to the differential equation, with the angular frequency stated.
For any other readers, this can also be solved by calculating the impedance directly and finding when it's a maximum, I was just looking for a short derivation.
My mistake. What i wanted to say is that we can solve the second order differential equation with the help of complex numbers. But that is quite long.
Ah ok, that is what I did, I wasn't aware there was another way to do it, I just omitted it from the working because it's the same for any question.
The method is shown http://tutorial.math.lamar.edu/Classes/DE/ComplexRoots.aspx" for those wondering how I suddenly leapt to the frequency from the characteristic equation. I just realized that if the system is to oscillate, the roots will be complex, so the trial solution will have a decay term e-R/2L multiplied by (Acosωt + Bsinωt)
(ω as above)
I thought that was the short derivation. That's how I did it. I just found the poles of the transfer function in extended Fourier space. It is just a few lines of algebra (depending on how much detail you want to show).
FAQ: Parallel LCR resonant frequency derivation for larger resistances
What is the formula for calculating the parallel LCR resonant frequency for larger resistances?
The formula for calculating the parallel LCR resonant frequency for larger resistances is fr = 1 / (2π√LC), where fr is the resonant frequency, L is the inductance in henries, and C is the capacitance in farads.
How does the resonant frequency change for larger resistances in a parallel LCR circuit?
As the resistance in a parallel LCR circuit increases, the resonant frequency decreases. This is because the larger resistance causes a decrease in the overall impedance of the circuit.
What is the significance of the resonant frequency in a parallel LCR circuit with larger resistances?
The resonant frequency in a parallel LCR circuit with larger resistances is the frequency at which the circuit will exhibit maximum current and minimum impedance. It is an important characteristic to consider when designing and analyzing electronic circuits.
Can the resonant frequency be adjusted in a parallel LCR circuit with larger resistances?
Yes, the resonant frequency in a parallel LCR circuit with larger resistances can be adjusted by changing the values of the inductance and capacitance in the circuit. This can be done by using different components or by adding or removing components from the circuit.
What are the practical applications of parallel LCR circuits with larger resistances and their resonant frequency?
Parallel LCR circuits with larger resistances and their resonant frequency have various practical applications in electronic devices, such as in radio and television receivers, electronic filters, and tuning circuits. They are also used in power supplies and in electrical power distribution systems to control and filter the flow of current.
