Parallel Plate Capacitor Question (Many Attempts)
In summary: You're supposed to be comparing the energy stored in the capacitor with and without the dielectric. You were given the energy with the dielectric, so you need to subtract the energy without the dielectric from this value. I think you have two problems. First, you calculated the energy with the dielectric incorrectly. Second, you subtracted the energy with the dielectric from the energy without the dielectric. It should be the other way around.Seems like quite a small change, thanks a lot for the help so far, been up late past few nights trying to do it alonehows that so far
MattNotrick
I have tried this set of questions which is from i-vii, I believe I am going wrong at a certain stage, as at question vi, the voltage is clearly wrong, below is the questions and my attempt. Sorry for the long post, any help on pointing out where I have gone wrong would be much appreciated, Thanks.
A parallel plate capacitor is constructed from two circular plates, radius 12cm and separated by a dieletric sheet with a thickness of 2 micro meters and relative permativity 6. The capacitor is charged to a potential difference of 110V
Questions
i) The area of one plate
ii) The capacitance
iii) The Charge on one plate
iv) The electric field between the plates
v) The energy stored in the capacitor
vi) The new potential difference if the dielectric is removed without changing the charge
vii) The plate separation is now changed to 1mm, find the energy compared to part v
Supplied within answers
i)Area = 0.0452m^2
ii)
c=εoεrA/d
C = (8.854x10^-12)(6)(0.0452) / (2x10^-6)
C=1.2x10^6F
iii)
Q=C/V
Q=(1.2x10^-6)(110)
Q=1.32x10^-4 C
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^-5 J
v)
E=1/2CV^2
E=1/2(1.2x10^-6)(110)^2
E=7.26x10^-3 J
vi) (I feel I have gone wrong here, maybe earlier?)
I transpose C=Q/V to get V=C/Q to work out the new potential difference?
I need to work out the new capacitance with no dielectric so
C=(8.854x10^-12)(0.04522)/(2x10^-6)
C=2x10^-7 so
V=2x10^-7/1.32x10^-4
V= 1.51 x 10^-11
which surely cannot be right?
vii) (Need question vi correct to answer this one)
New capacitance = 2.4x10^-9
E=1/2CV^2
E=(2.4x10^-9)(Need answer from above)^2
E= Old Energy - New Energy
Thanks for anyone willling to help, Rick.
Questions
ii) The capacitance
i)Area = 0.0452m^2
ii)
c=εoεrA/d
C=1.2x10^6F
Okay up to here, but you missed the sign of the exponent in the capacitance above.
iii)
Q=C/V
Q=(1.2x10^-6)(110)
Q=1.32x10^-4 C
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^-5 J
Watch your units. You divided volts (Joules/Coul) by distance (meters). Probably better to just leave the units as V/m.
v)
E=1/2CV^2
E=7.26x10^-3 J
Pretty much okay so far.
C=2x10^-7 so
You could simply have 'reversed' the effect of the relative permittivity of the dielectric by dividing the previous capacitance by it: [tex]C/\epsilon[/tex]
V= 1.51 x 10^-11
You want V = Q/C, but you performed V = C/Q.
Are you sure that this new capacitor contains a dielectric?
{snip}
ii) C=1.2x10^6F should be C=1.2x10^-6F ... typing mistake
iii) Q = C/V should be Q = CV ... typing mistake
iv)
E=v/d ... correct
E=110/2x10^-6 ... correct
E=5.5x10^-5 J ... wrong! Be careful how you enter the numbers in your calculator. 110/2*(1x10^-6) is not the same as 110/(2x10^-6).
vi) "I transpose C=Q/V to get V=C/Q"
If you were solving for V you would get V = Q/C. And yes you are correct, when using the wrong formula (to get V= 1.51 x 10^-11), it surely cannot be right.
Clean it up and press on, you're doing rather well, just made a couple of silly mistakes.
Ok guys thanks for the quick and helpfull response (is there a rep+ button?) you pointed out some mistakes for me, I've gone on and finished the question, I am unsure of a few units though. Here it is from iv)
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^7
v)
E=1/2CV^2
E=7.26x10^-3 J
vi) V=Q/C
C=2x10^-7 so
V=0.01452/(2x10^-7)
V= 72600
vii)
New capacitance = 4x10^-10 (no dielectric, thanks)
E=1/2CV^2
E=(2.4x10^-9)(72600)^2
E= 12.649824
12.649824-(7.26x10^-3)= 12.642564
hows that so far??
iv)
E=v/d
E=110/2x10^-6
E=5.5x10^7
Units are V/m
v)
E=1/2CV^2
E=7.26x10^-3 J
vi) V=Q/C
C=2x10^-7 so
V=0.01452/(2x10^-7)
V= 72600
Your value for the charge looks suspicious. I recall that you calculated it correctly earlier. The units of V should be, well, V (Volts). Always put units on your results.
vii)
E=1/2CV^2
E= 12.649824
Check your values used in the energy calculation. That doesn't look like the capacitance value you just calculated (or even half of it). The unit of Energy is J.
Related to Parallel Plate Capacitor Question (Many Attempts)
What is a parallel plate capacitor?
A parallel plate capacitor is a type of capacitor that consists of two parallel conductive plates separated by an insulating material, known as a dielectric. It is used to store electrical energy by creating an electric field between the plates.
What is the formula for calculating the capacitance of a parallel plate capacitor?
The formula for calculating the capacitance of a parallel plate capacitor is C = εA/d, where C is the capacitance in farads (F), ε is the permittivity of the dielectric material, A is the area of the plates, and d is the distance between the plates.
What factors affect the capacitance of a parallel plate capacitor?
The capacitance of a parallel plate capacitor is affected by three main factors: the area of the plates, the distance between the plates, and the permittivity of the dielectric material between the plates. Increasing the area of the plates or decreasing the distance between them will increase the capacitance, while using a material with a higher permittivity will also increase the capacitance.
How do I calculate the electric field between the plates of a parallel plate capacitor?
The electric field between the plates of a parallel plate capacitor can be calculated using the formula E = V/d, where E is the electric field in volts per meter (V/m), V is the voltage between the plates, and d is the distance between the plates.
What are some common applications of parallel plate capacitors?
Parallel plate capacitors have many practical applications, including filtering out unwanted frequencies in electronic circuits, storing energy in power supplies, and as sensors in electronic devices. They are also commonly used in radio and television broadcasting to tune the frequency of the signal.
