Parallel plate capcitor displacement current magnitude
In summary, the question is about using an integral form of Gauss's Law to show the relationship between the magnitude of D (electric displacement) inside a parallel plate capacitor and the charge and area of the plates. The solution involves calculating D in different regions and then using it to find E. It is also important to include both the free and bound charge in the equation for Gauss's Law.
neu
230
Use an integral form of the Gauss law to show how the magnitude of D inside the capacitor depends on the charge on the plates of a parallel plate capacitor and their area.
Gauss
[tex]\int{E.nda}=\frac{\rho}{\epsilon_{0}}[/tex]
[tex]\nabla.D=\rho[/tex]
where div, D, E all vectors
so [tex]\epsilon\int{D.nda}=\frac{\rho}{\epsilon_{0}}[/tex]
where integrals are all closed loops.
so integral over area = 2 pi r^2 : [tex] D.2.\pi.r^2=\epsilon_{r}\rho[/tex]
that right?
First of all, let's get the definition straightened out
[tex]\int \vec{D} \bullet d\vec{a} = Q_{f,enc}[/tex]
So the (closed) surface integral of [itex]D[/itex] depends only on the free charge enclosed by the volume that is bounded by this surface.
I don't understand your last question, but before we get to that, I'll try to explain:
Now, in the region between the plates, you have no free charge: there is bound charge (induced charge) on the dielectric surfaces facing the conducting capacitor plates, but that's all.
Don't write something like [itex]D = \epsilon E[/itex] right away. Work out the expression for D in the different regions and then get E.
I can argue by symmetry that D inside is normal to the capacitor plates (neglecting fringing) at all points. Further, D is zero inside the conductor (as P and E are both zero inside a conductor and [itex]D = \epsilon_{0} E + P[/itex]). Now, if [itex]\sigma[/itex] is the free surface charge density (=Q/A where A is the plate area and Q is the charge on the capacitor plate), then can you show that [itex]D = \sigma[/itex] everywhere?
Once you have D, you can easily get E.
Now to your last equation. If you want to use the integral form of Gauss's Law with E (rather than D) then please understand that the charge you write on the right hand side is the sum of the bound charge (the induced charge in the dielectric..whatever part of it that contributes to the flux through your chosen Gaussians surface) and the free charge (capacitor charge). So you have to be careful to include the bound charge in this expression as well.
Generally, since we control free charge (you charge the capacitor) and bound charge readjusts along the way to satisfy boundary conditions in local regions, its easier to work out D first and then E.
While this post might not have solved your problem completely, I hope you can take it from here with the hints given. But please feel free to reply back esp if you are stuck or want to discuss this further. Include your solution with your reasoning so we can see where the problem is.
Best wishes
Related to Parallel plate capcitor displacement current magnitude
1. What is a parallel plate capacitor?
A parallel plate capacitor is a type of capacitor that consists of two parallel conductive plates separated by a dielectric material. It is used to store electrical energy in an electric field.
2. What is displacement current?
Displacement current is the flow of electric charge that occurs in a region where there is a changing electric field. It is an important concept in electromagnetism and is described by Maxwell's equations.
3. How is the magnitude of displacement current in a parallel plate capacitor calculated?
The magnitude of displacement current in a parallel plate capacitor can be calculated using the equation I = ε0 * A * (dV/dt), where I is the displacement current, ε0 is the permittivity of free space, A is the area of the plates, and dV/dt is the rate of change of voltage between the plates.
4. What factors affect the magnitude of displacement current in a parallel plate capacitor?
The magnitude of displacement current in a parallel plate capacitor is affected by the voltage between the plates, the area of the plates, the distance between the plates, and the dielectric material between the plates.
5. Why is displacement current important in the study of electromagnetism?
Displacement current is important because it is a crucial part of Maxwell's equations, which describe the relationship between electric and magnetic fields. It also helps to explain the propagation of electromagnetic waves and plays a role in the design and functioning of various electrical devices.
  • Electromagnetism
