EmilyRuck
- 136
- 6
Hello!
You can find in the picture attached a parallel plate waveguide which has an a1 height before the step and an a2 height after the step. The plates are perfect conductors and the step is ideal.
I can't determine which physical quantities are continuous across this discontinuity.
Suppose that a TEM wave is travelling, with the showed Ex and Hy (outgoing from the screen). I'm sure the voltage is constant: if I connect DC power supply, the voltage V between the two plates is the same before and after the discontinuity. But the electric field?
If it was a condenser, we had
V = E*d
where d is the distance between the plates. So, if d changes, E changes too. But E must be continuous according to my notes !
What's wrong? The voltage cannot change!
Thank you anyway,
Emily
V = E*d
Thank you anyway,
Emily
