Parallel RLC circuit complex impedance graphing
lys04
85
How can I graph the impedance against the frequency using a logarithmic scale for the frequency axis?
$$ Z = \frac{iwL-w^{2}RLC}{1-w^{2}LC+iwRC} $$
^^ as mentioned in the homework statement, the relevant equation is my worked out impedance for the circuit. I have attached a diagram of the circuit below.
##Z## is complex. You want to write it as ##|Z| e^{j\phi}##. Do you know how to do that ?
Is it like this? for the branch with resistor and capacitor,
And then for the branch with just the inductor in it its just wLe^90j?
And then I need to add them together which is 1/Z = 1/Z_l + 1/Z_c?
No. You already did the work to get the correct complex ##Z##.
To write it as ##|Z| e^{j\phi}## you want to use ##|Z|^2=ZZ^*## with ##Z^*## the complex conjugate.
And ##\tan\phi = \Im Z/\Re Z## (imaginary part / real part).
If ##Z= (a+jb)/(c+jd)## you get the real and imaginary part by multiplying with ##(c-jd)/(c-jd) ## (because then the denominator ##c^2-d^2## is real).
