Parallel transport analog of Stoke's theorem
In summary, the conversation is discussing the possibility of a similar theorem to Stokes theorem existing for parallel transport. The Riemann curvature tensor is mentioned as a potential factor in this theorem, but there are difficulties in defining and integrating over closed loops in higher dimensions. The conversation also delves into the concept of parallel transport and its relation to GL(n) and gl(n), with the conclusion that the theorem may not work as expected due to the complexities involved in defining and integrating over closed loops in higher dimensions.
waht
1,501
In a Stokes theorem, the integral of all curls of a vector field enclosed in some region is equal to the line integral around the boundary.
I'm wondering if a similar theorem exists for parallel transport. The Riemann curvature tensor gives a change in a vector when parallel transported around a small loop. If we were to parallel transport a vector around a much larger loop, would the change in the vector be proportional to the integral of the Riemannian tensor around small loops inside the larger loop?
You'll have to be more specific, since as it stands, nothing is well-defined. Integration gives a number. Unless you're in dimension two (where the curvature tensor is ~ Gaussian curvature, which is a function), you'll have to input specific vectors into the curvature tensor to even get a number to come out when you integrate.
On the other side of the equation, you have a vector. I'm not sure how one would make the necessary changes so that the sides would come out apples to apples. The closest thing (in dimension two) would be the Gauss-Bonnet theorem, and in higher dimensions, the Chern-Gauss-Bonnet theorem. However, it doesn't seem to do exactly what you want it to do. One immediate problem is that you would have a very difficult time "integrating" over the "interior" of a closed loop, if you're in dimension greater than two - it's just not possible to do it with the volume element on a Riemannian manifold. You could attempt to generalize to boundaries of submanifolds, but then you're not working with vectors and loops anymore.
In a broader sense, curvature does measure the non-commutativity of mixed covariant derivatives, so it seems like you're barking up the right tree. But I just don't think it's going to work the way you'd like.
yea basically the idea is to integrate non-commutativity (or non-commutativite density) in a 2D closed region on a plane spanned in some nth dimensional manifold, and hoping it would equal to the change of a vector parallel transported around the boundary.
I guess that's not possible, thanks for clarifying
Something's fishy here; what have I done wrong? (Or am I right?)
Let's suppose our n-dimensional manifold M can be covered by a single coordinate chart. The chart provides an isomorphism TM --> R^n. In these coordinates, parallel transport is a function P that takes any curve c and returns an element P(c) of GL(n).
Parallel transport is (?) differentiable, so given any tangent vector v to a point p, the derivative of P gives us an element P(v) of gl(n).
In other words, there is a gl(n)-valued one-form A such that P(c) is computed by integrating A along c. (A can be written as n^2 ordinary one-forms)
Now, by Stoke's theorem, if a closed loop c is the boundary of an (oriented) surface S in M, then P(c) can be computed by integrating dA over all of S. In particular, it doesn't matter what surface you use, they all give the same value.
Isn't that essentially what waht is trying to think of?
Could dA can be the riemann curvature tensor?
If I understand the tensor correctly, you give it two vectors to define a plane, and a third vector v to be parallel transported around an infinitesimal closed loop on the plane; the result will be a change in the vector v after completing the circuit.
By integrating the tensor in a region inside a closed curve c on the plane, by (stoke's theorem or any other theorem?), the result should be the same as if doing the parallel transport of the vector v around the curve c; or integrating the riemann tensor along c?
I'm not quite sure what you're trying to do with that, but it certainly wouldn't be GL(n)-valued - parallel transport is trivial in R^n.
I'm not using the standard connection on Rn. I'm using the (coordinate representation of the) connection on M.
More explicitly: parallel transport along c is a linear isomorphism
P(c) : Tc(0)M --> Tc(1)M
My coordinate chart yields a basis for TM, and thus linear isomorphisms
Rn --> Tc(0)M
Rn --> Tc(1)M
And thus the coordinate representation of P(c) is the composite
Rn --> Tc(0)M --> Tc(1)M --> Rn
which is an element of GL(n).
It ought to work if you take the standard connection on R^n, right? You're taking the derivative of the identity, which you claimed was an element of GL(n). That's what I'm disagreeing with.
Ah, I see.
Well, I can definitely take the derivative, and reconstruct the identity by integrating zero along the curve, so that part works. And 0 is an element of gl(n).
But I suppose that the derivative wouldn't need to be in gl(n). (?) I know there's some good Lie group/algebra stuff going on, but I can never manipulate that as adeptly as I would like; I suppose there should really be an exponential or logarithm in there to do things 'right'.
Ah right.
Let P(c,t) denote parallel transport along the subcurve of c with domain [0,t]. The derivative wrt t is going to be in the tangent space to GL(n) at P(c,t), but we really do want to "normalize" it to an element of gl(n), and so we need to translate back to the identity on GL(n).
By P being differentiable, what I mean is that there is a gl(n)-valued one-form A (whose definition doesn't depend on the choice of c) satisfying
(d/dt) P(c,t) = A(dc/dt) P(c,t)
But recovering P(c) is no longer simply the integral of a one-form, and that was my mistake.
Oh, but in a two-dimensional surface, if we actually had a metric and chose an orthonormal basis, SO(2) is commutative, so the equation above becomes
(d/dt) log P(c,t) = A(dc/dt)
and so the logarithm of P(c) can be recovered by integrating a one-form, and thus we can use Stoke's theorem and everything works out!
You could still do what I suggested, but each different curve c would have yielded an entirely different A, and therefore wouldn't be all that useful!
Sorry to go off on a tangent (heh heh). At least it was useful for me...
can we integrate a riemann tensor over a region inside a closed curve?
Related to Parallel transport analog of Stoke's theorem
1. What is the Parallel Transport Analog of Stoke's Theorem?
The Parallel Transport Analog of Stoke's Theorem is a mathematical concept that relates to the transport of a vector along a closed curve on a curved surface. It is an extension of Stoke's Theorem in three-dimensional space.
2. How does the Parallel Transport Analog of Stoke's Theorem differ from Stoke's Theorem?
The main difference between the two theorems is that the Parallel Transport Analog deals with curved surfaces, while Stoke's Theorem is only applicable in flat, three-dimensional space. The Parallel Transport Analog also takes into account the change in direction of the vector as it is transported along a closed curve.
3. Why is the Parallel Transport Analog of Stoke's Theorem important in science?
The Parallel Transport Analog of Stoke's Theorem has many applications in fields such as physics, engineering, and mathematics. It is used to analyze fluid flow, electromagnetism, and other physical phenomena on curved surfaces. It also has implications in the study of differential geometry.
4. What is the mathematical formula for the Parallel Transport Analog of Stoke's Theorem?
The formula for the Parallel Transport Analog of Stoke's Theorem is ∫C (∇u V) · dS = ∫S (curl V) · dS, where C is a closed curve on a curved surface, ∇u represents the parallel transport of the vector V along the curve, and curl V is the curl of V on the surface S bounded by the curve C.
5. Are there any practical applications of the Parallel Transport Analog of Stoke's Theorem?
Yes, there are many practical applications of the Parallel Transport Analog of Stoke's Theorem. Some examples include calculating the circulation of a fluid around a curved object, determining the magnetic field around a curved wire, and analyzing the flow of air around a curved airplane wing. It is also used in computer graphics to model the behavior of light on curved surfaces.
  • Differential Geometry
  • Beyond the Standard Models
  • Quantum Physics
