MHB Parallelogram ABCD: Finding AC from PB & PD
anemone
MHB
POTW Director
In parallelogram $ABCD$, $\angle B$ and $\angle D$ are acute while $\angle A$ and $\angle C$ are obtuse. The perpendicular from $C$ to $AB$ and the perpendicular from $A$ to $BC$ intersect at $P$ inside the parallelogram. If $PB=700$ and $PD=821$, find $AC$.
Mathematics news on Phys.org
[TIKZ]
\coordinate[label=left:B] (B) at (0,0);
\coordinate[label=right:C] (C) at (12, 0);
\coordinate[label=above:A] (A) at (3,10);
\coordinate (F) at (3,0);
\coordinate (E) at (0.991,3.303);
\coordinate[label=above: P] (P) at (3,2.7);
\coordinate[label=above: D] (D) at (15,10);
\draw (A) -- (B)-- (C)-- (D) -- (A);
\draw (C) -- (E);
\draw (A) -- (F);
\draw (P) -- (D);
\draw (F) rectangle +(-0.2, 0.2);
\draw[thick,dashed] (9,6.35) circle (7.023cm);
\begin{scope}[shift={(1,0)}]
\node[draw,rectangle,rotate=71] at (0.16,3.395){};
\end{scope}
[/TIKZ]
First note that $P$ is the orthocenter of $\triangle ABC$. Furthermore, note that from the perpendicularity $DA\perp AP$ and $DC\perp CP$, so quadrilateral $DAPC$ is cyclic. Furthermore, $DP$ is a diameter of circle $(DAPC)$. This is the circumcircle of $\triangle DAC$, which is congruent to $BCA$. As a result, if $R$ is the circumradius of $\triangle ABC$, then $PD=2R$.
Now I claim that $PB=2R\cos B$. To prove this, reflect $P$ across $AB$ to point $P'$. It is well-known that $P'$ lies on the circumcircle of $\triangle ABC$, so in particular the circumradii of $\triangle APB$ and $\triangle ACB$ are equal. But then by Law of Sines \[\dfrac{BP}{\sin\angle BAP}=\dfrac{BP}{\cos B}=2R\quad\implies\quad BP = 2R\cos B\]as desired. (An alternate way to see this is through the diagram itself: from right triangle trigonometry on triangles $DAP$ and $DCP$ it is not hard to see that $PA=2R\cos A$ and $PC=2R\cos C$, which by symmetry suggests $PB=2R\cos B$.)
Finally, note that by Law of Sines again we have $AC=2R\sin B$, so \[AC^2+BP^2=(2R\sin B)^2 + (2R\cos B)^2 = (2R)^2(\sin^2 B+\cos^2 B) = PD^2.\]Hence \[AC^2=PD^2-PB^2=821^2-700^2=(821-700)(821+700)=11^2\cdot 39^2\]and so $AC=11\cdot 39=\boxed{429}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
