Parameterization of a Circle Question
  • Thread starter royblaze
  • Tags
    Circle
In summary, the conversation discusses the concept of parametrization in Calculus, specifically for finding the curvature of curves in 3D space. A circle of radius 3 is used as an example, with the parametric equation r(t) = 3cos(t)i + 3sin(t)j. The speaker is confused about why the "x" and "y" parts of the parameterization have to be cosine and sine trig functions, respectively. It is explained that this convention is based on the orientation of the curve and can vary depending on the starting point and direction. The speaker expresses gratitude for the clarification.
royblaze
74
This isn't really a HW question, it's just something that's been confusing me in my Calc class.
We recently went over how to find curvatures of curves in 3D space. In lecture, the professor went over a simple example: a circle of radius 3 at any given point.
Maybe it's because I don't remember my Calc II class that well, but he parameterized the equation of a circle,
x2 + y2 = 9
to become r(t) = 3cos(t)i + 3sin(t)j .
So from:
x2 + y2 = r2
If x = cos(t) and y = sin(t), the identity cos2(t) + sin2(t) = 1 still holds true.
If the radius is 3,
x2 + y2 = 32
3(x2 + y2) = 9(12)
9cos2(t) + 9sin2(t) = 9(12)
9(cos2(t) + sin2(t)) = 9(12)
is how I understand it. If there's an easier way to picture it, please let me know!
So then r(t) = 3cos(t)i + 3sin(t)j describes the circle when "traced."
My question: why does the "x" part and the "y" part of the parameterization have to be the respective cos, sin trig functions? In class, one student said that x was sin; but the prof said that no, it's cos. Why does x have to be cos, rather than sin? Does it have to do something with the direction the curve "goes in?" How can I determine the "direction" the curve goes in? Or did I just hear my professor wrong...?
Try drawing a picture. Do you remember your unit circle? For a right-handed coordinate system, x = rcos[itex]\theta[/itex] and y the sine function. Positive theta corresponds to counter-clockwise motion from the positive x-axis.
Now when you parametrize the equation [itex]\theta[/itex] becomes [itex]\dot{\theta}[/itex]t, where [itex]\dot{\theta}[/itex] is how quickly you are going around the circle. In your case this is simply one.
Strictly speaking, x doesn't HAVE to be the cosine. It's just convention to use a right handed coordinate system. If you measured [itex]\theta[/itex] from a different axis or you switched positive x being in the vertical, your sines and cosines may change.
Yes, it has to do with the orientation of the curve and where you want it to be when t = 0. Parameterizations are in general not unique. If the curve is specified to start at (1,0) and go counterclockwise then R(t) = < cos(t), sin(t) > is a natural choice. If it went clockwise you might use <cos(t), -sin(t)>. If nothing is given about the orientation of the curve then you could use <sin(t), cos(t)> or other choices; they are all equally correct.
x2 + y2 = 9
So from:
x2 + y2 = r2
If the radius is 3,
x2 + y2 = 32
3(x2 + y2) = 9(12)
They don't have to be. There exist an infinite number of parametric equations describing any curve. [itex]x= 3sin(t)[/itex], [itex]y= 3cos(t)[/itex] are perfectly good parametric equations and, in fact, have the same "direction" as [itex]x= 3cos(t)[/itex] [itex]y= 3sin(t)[/itex]: with the first, as t goes from 0 to [itex]\pi/2[/itex], (x, y) goes from (0, 3) to (3, 0), counter-clockwise around the circle and the second goes from (3, 0) to (0, 3), also counterclockwise.
But before you go telling your teacher that we say he/she is wrong, note that they do have different points for specific values of t. The parametric equations [itex]x= cos(t)[/itex], [itex]y= sin(t)[/itex] "start" (t= 0) at (1, 0) and then go around the circle. Perhaps for some reason, that is important.
Wow, thank you all for the absolutely fantastic replies. It REALLY cleared it up for me, big time.
Thanks again!
FAQ: Parameterization of a Circle Question
What is parameterization of a circle?
Parameterization of a circle is a method of representing points on a circle using a single variable, typically denoted by t. This allows for easy calculation and manipulation of points on the circle.
How is a circle parameterized?
To parameterize a circle, we use the equations x = r*cos(t) and y = r*sin(t), where r is the radius of the circle and t is the parameter variable. These equations give us the x and y coordinates of any point on the circle.
3. Why do we use parameterization for circles?
Parameterization allows for easier manipulation and calculation of points on a circle, making it useful in many mathematical and scientific applications. It also allows for efficient representation of curves and surfaces in higher dimensions.
4. How is the direction of parameterization determined?
The direction of parameterization is determined by the orientation of the circle. If the circle is traced in a counter-clockwise direction, the parameter t increases in value. If traced in a clockwise direction, t decreases in value.
5. Can a circle be parameterized in any other way?
Yes, a circle can also be parameterized using polar coordinates, where r is the distance from the origin and θ is the angle from the positive x-axis. The equations x = r*cos(θ) and y = r*sin(θ) are equivalent to the regular parameterization equations x = r*cos(t) and y = r*sin(t).
