Parameterization of a torus problem
  • Thread starter mcafej
  • Tags
    Torus
In summary: So I think I have all the answers to this problem now, thank you guys!In summary, the parametrization of the torus given by x = (3 + cos(s)) cos(t), y = (3 + cos(s)) sin(t), z = sin(s) is used to find the radius of the circle that runs through the center of the tube and the radius of the tube itself. The radii are found by looking at the variation of x^2 + y^2 as a function of s and t. The rate of coverage of the torus is also computed by simplifying the cross product of the velocity vectors and taking the magnitude. The area of the torus is then found by using the double integral
mcafej
Consider the parametrization of the torus given by:
x = x(s, t) = (3 + cos(s)) cos(t)
y = y(s, t) = (3 + cos(s)) sin(t)
z = z(s, t) = sin(s),
for 0 ≤ s, t ≤ 2π.
(a). What is the radius of the circle that runs though the center of the tube, and what is
the radius of the tube, measured from the central circle?
(b). Compute the rate of coverage of the torus by the parametrization. (Look for simplifi-
cations using trig identitites.)
(c). The parametrization is 1-1. Compute the area of the torus.
Rate of coverage
|<∂x/∂s, ∂y/∂s, ∂z/∂s>x<∂x/∂t, ∂y/∂t, ∂z/∂t>|
(if this is hard to read, its basically the magnitude of the cross product of the velocity vectors)
Given that the transformation is 1-1 on a finite region D, the area on the s-t plane covered by the parameterized surface is
∫∫|<∂x/∂s, ∂y/∂s, ∂z/∂s>x<∂x/∂t, ∂y/∂t, ∂z/∂t>| dsdt
(in other words, the area covered by the torus is going to be the double integral of the rate of coverage with respect to s and t)
Part b and c are pretty straight forward. For part B, I use the equation he gave us, for rate of coverage (listed above). Finding the partials, the cross product and the magnitude is pretty straight forward (although they are very confusing). I ended up with
Cross product of the velocity vectors is
<-cos(s)cos(t)(3+cos(s)), -sin(t)cos(s)(3+cos(s)), (-3-cos(s))(sin(s)cos2(t)+sin2(t)cos(s)>
Then I need to take the magnitude of that, but I can't figure out how to simplify it using trig identities (taking the magnitude of that mess would be a nightmare, but I may need to just sit down and do it, is there any easier way?). The last one looks like I should be able to simplify more cause I have the sin2 and cos2, but I can't figure out how to because they are both attached to a sin(s) and cos(s).
For part c, I just take my answer from part b and plug it into the integral. The hard part about this question is the bounds of the integral. I know that 0≤s and t≤2π, but I have know idea what the upper bound for s should be and what the lower bound for t should be.
As for part a, I really have no clue how to even get started on this one. I have a feeling it has something to do with the 3 in the equation, but I really don't know. I'm not sure which of s or t relates to the circle that runs through the center of the tube, and which is related to the radius of the tube itself. Sorry if this is a little confusing. If you have any questions about anything, just let me know.
for 0 ≤ s, t ≤ 2π.
Look at ##x^2+y^2## and see how it varies as a function of ##s## and a function of ##t## to get an idea about the two radii.
Ok, so I just looked up the formula for the radii of a torus, and I just explained how I got 1 as the radius of the circle of the tube, and 3 as the radius of the torus itself. As for the Area of coverage, I was able to simplify it down and for the Area you end up just getting the double integral from 0 to 2pi (for both s and t) of 3+cost. I ended up getting 12pi^2 for the integral, which is the surface area of the torus (which is correct because the surface area of a torus and it is 4rRpi^2, with r being the radius of the tube and R being the radius of the torus, so 4*3*1*pi^2=12pi^2 as needed). The response before was helpful about deriving the radii of the torus, thank you.
Related to Parameterization of a torus problem
1. What is a torus?
A torus is a three-dimensional geometric object that resembles a donut shape, with a hole in the middle. It is created by rotating a circle around an axis that does not intersect the circle.
2. What is parameterization?
Parameterization is the process of representing a geometric object using mathematical parameters, such as equations or coordinates. This allows for the object to be described and manipulated in a more simplified and systematic way.
3. Why is parameterization important in the study of tori?
Parameterization is important in the study of tori because it allows for the object to be described and analyzed more easily. It also allows for the calculation of various properties and the creation of computer models and simulations.
4. How is a torus problem typically parameterized?
A torus problem is typically parameterized by defining the radius of the torus and the distance between the center of the torus and the center of the circle that is being rotated to create the torus. These parameters can then be used to generate equations for the torus.
5. What are some real-life applications of parameterization of a torus problem?
The parameterization of a torus problem has numerous real-life applications, such as in computer graphics and animation, engineering and design, and physics and mathematics. For example, it can be used to create 3D models of objects in computer graphics, to design and analyze structures in engineering, and to study the behavior of fluids in physics and mathematics.
