Parameterizing Planes Question #2
  • Thread starter RJLiberator
  • Tags
    Planes
In summary, the equation of the plane containing the line r(t) = <2 − t, 3, 4 + 2t> and point P(0, 0, 1) can be found by taking the cross product of the line's direction vector and the difference of two points on the plane (P and a point on the line). This results in a normal vector, which can then be used to find the equation of the plane.
RJLiberator
63
Equation of the plane
Containing the line r(t) = <2 − t, 3, 4 + 2t> and point P(0, 0, 1).
ax+by+cz=d equation of a plane
1) We have a point, we need a normal vector
2) this time we are giving a line ON the plane, so the direction vector won't work as it is parallel to the plane.
3) Therefore, we can find the normal vector by using the point (0,0,1) and the point from the giving line (2, 3, 4) and making their line segment which comes out to be <-2, -3, -3>.
We then use this line segment and the direction vector <-1, 0, 2> take their cross product to net a vector that is perpendicular to the plane <6, -7, 3>.
And the equation of this plane becomes 6x-7y+3z=3
which satisfies both of our giving points (0, 0,1) and (2, 3, 4) on the plane.
The thing i am unsatisfied with here is why can we use 2 points on the plane, take their difference, and then cross it with the direction vector to get the perpendicular normal vector?
I understand that the cross product nets a perpendicular vector, but not the first part.
If you take two points in the plane and take their difference that gives you one vector that is tangent to the plane. The direction vector to the line is also tangent to the plane. If you take the cross product of the two that is perpendicular to both of them. Hence is a normal vector to the plane.
Likes RJLiberator
Okay, my followup question:
You say that the difference results in one vector that is tangent to the plane.
The direction vector is also tangent to the plane.
Tangent does NOT equal perpendicular, so we can't use these as normal vectors.
But does tangent = on the plane? If so, we can use these to take their cross product and receive a normal vector and all is well.
You are confusing position vectors with direction vectors. Only position vectors need to be 'on the plane'. The difference of two position vectors is a direction vector. The normal is not a position vector. It just points in a direction. Same for tangent. Is this making any sense?
Likes RJLiberator
Yes, getting there.
So a position vector comes from the origin to the point on the plane.
The direction vector does not do this, but instead can go through this 'line segment' that we've created from the difference.
So when taking the difference of two points on the plane we get a direction vector that 'connects' these two points. With this direction vector AND the giving direction vector of the line, this cross product results in the normal vector we are looking for.
Is that correct reasoning?
RJLiberator said:
Yes, getting there.
Yes, some vectors indicate a position in space (position vectors). Some vectors just need to indicate a direction. The direction of <1,1,1> is the same as the direction of <2,2,2>. But regarded as position they are different.
Likes RJLiberator
Thank you for clarifying this for me. You have been a great advisor/helper. :)
FAQ: Parameterizing Planes Question #2
1. What is the purpose of parameterizing planes?
The purpose of parameterizing planes is to represent the points on a plane in terms of two independent variables. This allows for a more efficient and organized way to describe and analyze points on a plane.
2. How do you parameterize a plane?
To parameterize a plane, you must first determine the two independent variables, usually denoted as u and v. Then, you can use a parameterization formula to express the x, y, and z coordinates of any point on the plane in terms of u and v. This can be done using vectors or parametric equations.
3. What is the difference between a vector and parametric equation for parameterizing a plane?
Both vectors and parametric equations can be used to parameterize a plane. A vector parameterization uses the direction and magnitude of vectors to describe points on the plane, while a parametric equation uses a set of equations to define the coordinates of the points. Both methods yield the same result, but some may prefer one over the other depending on the situation.
4. Can any plane be parameterized?
Yes, any plane in three-dimensional space can be parameterized. However, the method of parameterization may vary depending on the specific characteristics of the plane, such as its orientation and distance from the origin.
5. How is parameterizing planes useful in real-world applications?
Parameterizing planes is useful in many real-world applications, such as computer graphics, engineering, and physics. It allows for precise and efficient calculations and analysis of points on a plane, which can be used to model and simulate various scenarios and phenomena in these fields.
