Parameters of a distribution of a physical variable
In summary, the parameters of a distribution of a physical variable describe the characteristics and behavior of the variable's values in a given dataset. These parameters typically include measures such as the mean, median, variance, and standard deviation, which provide insights into the central tendency and spread of the data. Understanding these parameters is crucial for analyzing the distribution's shape, identifying patterns, and making predictions about the physical variable's behavior in various contexts.
tworitdash
108
Pardon me if this is a very silly question. Although my research involves a lot of probability distributions, I consider myself a fledgling statistician.
When people assign a probability distribution to a variable in a physical process, is it inherently assumed that the parameters of this distribution are not related to each other?
My intuition says yes. If for example I assign a variable with a two parameter distribution and they are somehow dependent on each other, then it should be formulated as an one parameter distribution instead. Am I correct?
I have a similar situation in my research and I found in literature that the diameter of raindrops is gamma distributed with two parameters [itex] \eta [/itex] (shape parameter) and [itex] \Lambda [/itex] (inverse scale parameter - inversely proportional to the mean diameter in a volume). In old literature people really considered them to be independent parameters, but the current literature in this field show quite different results. When they try to fit it with gamma they really see a dependency of these two parameters.
This dependency can not be explained by any sort physical theory. Then, should the diameter be modeled by a different distribution instead?
Likes WWGD
No. That completely depends on the subject. A subject expert may, or may not, say that there is a relationship between the parameters.
If you know that for sure and there are no exceptions, then that sounds appropriate. The disadvantage is that any confidence intervals on the parameter would not be easily calculated from the standard, two-parameter distribution. But there is no easy way to avoid that problem if the parameters really are related.
It is a different distribution. The theory of gamma distributions depends on the parameters being constants.
Likes tworitdash
Thanks for the answer; I really appreciate it. What do you mean by constants here? For example, the claim is that the drop diameters are gamma distributed , but depending on different kinds of physical conditions the parameters of this distribution can vary (Like a different mean diameter in the volume or a different shape). However, for one specific physical condition, they are constants. The relation that people find between these parameters is when they arrange the data with all possible physical conditions. They see that there is either a linear and a quadratic relation between shape and the reciprocal of the mean diameter. I just explained this so that we are on the same page. If by constants you meant one type of physical condition, then we are on the same page and I think these parameters shouldn't be related to each other with varying physical conditions.
It sounds like I misinterpreted your original question.
I mean that for each case where you do statistical analysis, each parameter has a single value.
That is not a problem, as long as you just deal with one physical condition at a time for each analysis.
Good. So for a given physical condition, you can do the usual analysis using the Gamma function and those particular parameter values.
Yes.
That is a different problem from what I was originally thinking. I think that you could apply the Chi-squared Goodness of Fit test to a large sample from a variety of physical conditions to see if you can reject their theory of a particular relationship between the parameters.
If you have data from a variety of physical conditions, you can use their theorized parameter relationship to estimate the number of datapoints that should (on average) have certain values. Then you can test whether the data fits that theory. It might require a lot of data to get a strong test.
ADDED UPDATE: Their theoretical model should not rely on the data you use for your Goodness of Fit test, otherwise their model might be rigged to pass the test for that specific set of data.
Likes tworitdash
Yes.
Thanks for the reply again. I like the discussion. I also discussed with one of my professors, and I think for me it is very difficult to disprove the theories people made over the last 50 years. I see different relations between these two parameters, and all of them are empirical. And, I also don't have access to a sensor that can record all sort of conditions. I already have estimation procedures of my own to find parameters given the measurements from a sensor collected from different dates. I will keep these parameters independent and estimate them. At the end I will see a relation if there is any. Secondly, the estimation I perform has a likelihood function. It is a function of space. I can really assess these models based on a goodness of fit (based on my likelihood). This information will really assess if at all a Gamma distribution is adequate or not.
Likes FactChecker
FAQ: Parameters of a distribution of a physical variable
What are the common parameters used to describe a distribution of a physical variable?
The common parameters include the mean (or average), median, mode, variance, and standard deviation. These parameters help in understanding the central tendency, spread, and shape of the distribution.
How is the mean of a distribution calculated?
The mean is calculated by summing all the values of the variable and then dividing by the number of values. It provides a measure of the central tendency of the distribution.
What does the variance of a distribution represent?
Variance measures the spread of the values around the mean. It is calculated as the average of the squared differences from the mean. A higher variance indicates that the values are more spread out.
Why is the standard deviation important in describing a distribution?
The standard deviation is the square root of the variance and provides a measure of the spread of the values in the same units as the original data. It is crucial for understanding how much the values deviate from the mean.
What is the significance of the skewness and kurtosis parameters?
Skewness measures the asymmetry of the distribution, indicating whether the values are skewed towards the left or right. Kurtosis measures the "tailedness" of the distribution, indicating the presence of outliers. Both parameters provide insights into the shape of the distribution.
