Parametric and canonical equation of the line
In general, use parentheseswhen you write fractions on one line, as in (a - b)/c. Or, if you're not allowed to use parentheses, write a line of fractions like7/2 = 3/1 = 1/4. That way, the reader will know what you mean.
says
594
Find the parametric and canonical equation of the line L passing through the points A = [1, 0, 2] and B = [3, 1, −2]; check whether the point M = [7, 3, 1] lies on L.
Canonical equation of a line in space
x-x0 / l = y-y0 / m = z-z0 / n
Parametric equation of a line
x=lt+x0
y=mt+y0
z=nt+z0
where x0 y0 z0 are coordinates of a point sitting on the line
l,m,n are coordinates of the direction of the line
The vector AB = B - A = [3, 1, −2] - [1, 0, 2] = [2,1,-4]
To see if M sits on the line we sub in it's coordinates into both equations:
Canonical =
7-1 / 2 = 3-0/1 = 1-2/4
6/2=3/1≠-1/-4
Parametric
7 = 2t+1
3 = 1t+0
1 = -4t+2
6=2t
3=1t
-1=-4t
Because we have an inequaity / inconsistency in the z component we can conclude that the point M = [7,3,1] does not lie on the line L. For M to lie on the line L all three equations would have to equal each other in canonical form, and in parametric form all values of t would have to be the same.
Just wondering if my conclusion is correct? Thanks :)
Yes, your conclusion, that M is not on the line, is correct. However, I notice that you did NOT actually show the equations of this. Did you find them and just not show them here?
Likes says
When you write fractions like the ones above on one line, you need parentheses.
Otherwise, because of the precedence of division over subtraction, the line just above means ##7 - \frac 1 2 = 3 - \frac 0 1 = 1 - \frac 2 4##, which is certainly not what you meant.
Instead of 7 - 1/2, write (7 - 1)/2 when you write this on one line.
Likes says
Related to Parametric and canonical equation of the line
1. What is a parametric equation of a line?
A parametric equation of a line is a set of equations that express the coordinates of points on a line in terms of one or more variables, called parameters. These parameters represent the position of a point on the line and can be used to calculate the coordinates of any point on the line.
2. How is a parametric equation of a line different from a slope-intercept equation?
A parametric equation of a line is different from a slope-intercept equation in that it uses parameters to represent the position of a point on the line, while a slope-intercept equation uses the slope and y-intercept of the line to express its equation. A parametric equation can also represent lines that are not necessarily straight, while a slope-intercept equation can only represent straight lines.
3. What is a canonical equation of a line?
A canonical equation of a line is a standard form of writing the equation of a line, where the coefficients of the variables are simplified and the line is expressed in terms of its slope and y-intercept. It is often written as y = mx + b, where m is the slope and b is the y-intercept. This form makes it easier to identify the slope and y-intercept of the line and to graph it.
4. How is a canonical equation different from a parametric equation?
A canonical equation and a parametric equation are different in that a canonical equation expresses the equation of a line in terms of its slope and y-intercept, while a parametric equation uses parameters to represent the position of a point on the line. Additionally, a canonical equation is always written in the form of y = mx + b, while a parametric equation can have different forms depending on the number of parameters used.
5. Can a parametric equation and a canonical equation represent the same line?
Yes, a parametric equation and a canonical equation can represent the same line. However, the parametric equation may have a different form and include additional parameters, while the canonical equation will always be in the form of y = mx + b. It is also possible for a parametric equation to represent a line that is not a straight line, while a canonical equation can only represent straight lines.
