Parametric function - double points
In summary, In order to solve the homework equation for t, the student looked at a graph of y= cos(x), found that cos(x)= cos(2\pi- x), and then tried to find the two values of t for E=[0, Pi/2] by looking at the graph.
JPC
206
The parametric function :
x = cos(5t)
y= cos(3t)
t belongs to R
Question : find the coordinates (x, y) of the double points
OK so first of all,i find an interval of t where to study
- periodic of 2Pi
- M(t) = M(-t)
- M(t+Pi) is the symmetric of M(t) by point O
- M(Pi-t) is the symmetric of M(t) by point O
So i decide to study on E=[0, Pi/2], and then just do the symmetric by O to get it on [0, Pi]
and since M(t) = M(-t), then i have it on [-Pi, Pi], which is an interval of 2Pi, meaning that i have it on R.
here is a graph
Now i need to get the coordinates (x, y), of the 4 "double points"
knowing that there is a symmetry by O, i just need to find the coordinates of 2 non-symmetric of the 4.
but now i am stuck, because we have just spent one class all this, what is the method to find these double points ?
Logically, if 'u' belongs to E=[0, Pi/2] and 'w' belongs to F=[Pi/2, Pi],
we are looking for x(u) = x(w) AND y(u) = y(w)
but i was thinking we might need to use the symmetry too
so, we consider 'z' belongs to E=[0, Pi/2], with
x(w) = - x(z)
y(w) = - y (z)
I have tried with this, but doesn't give me any concluding results, since it just expresses me w with z :D
Yes, cosine is periodic with period [itex]2\pi[/itex]. Looking at a graph of y= cos(x), you should also see that it is true that [itex]cos(x)= cos(2\pi- x)[/itex]. Thus, to have x= cos(5t)= cos(5s) and y= cos(3t)= cos(3s) we must have either [itex]5t= 5s+ 2n\pi[/itex] and [itex]3t= 3s+ 2k\pi[/itex] or [itex]5t= \2npi- 5s[/itex] and [itex]3t= 2k\pi- 5s[/itex].
In the first case we have [itex]5(t-s)= 2n\pi[/itex] and [itex]3(t-s) 2k\pi[/itex] which means [itex]t-s= M(2\pi)[/itex] is divisible by both 3 and 5: divisible by 15.
Thank you
but from there how do i find the two values of 't' in E=[0, Pi/2] ?
by looking at the graph, with x=0.5 and x=-0.5, its easy to say the two values of t for E=[0, Pi/2] are : Pi/15 and 2Pi/15
(once i have the (x, y) coords of these 2 double points, its easy to get those of the 2 others by (-x, -y) )
FAQ: Parametric function - double points
What is a parametric function?
A parametric function is a mathematical function that defines a set of coordinates in terms of one or more parameters. These parameters can be changed to produce a different set of coordinates, allowing for a more flexible and dynamic representation of a relationship between variables.
What are double points in a parametric function?
Double points in a parametric function refer to points where the function intersects itself, creating two distinct points with the same coordinates. These points can occur when two or more parameters have the same value, resulting in two solutions for the same set of coordinates.
Why are double points important in parametric functions?
Double points can provide valuable information about the behavior and characteristics of a parametric function. They can help identify symmetries, critical points, and intersections with other functions. Additionally, studying double points can reveal insights about the underlying relationships between variables in the function.
How can I determine the location of double points in a parametric function?
The location of double points in a parametric function can be determined by solving for the parameter values that result in the same set of coordinates. This can be done algebraically by setting the equations for each variable equal to each other and solving for the parameters. Alternatively, you can use a graphing tool to visualize the function and identify the points of intersection.
Can double points occur in any type of parametric function?
Yes, double points can occur in any type of parametric function as long as there are multiple parameters that can result in the same set of coordinates. However, the frequency and location of double points may vary depending on the specific function and its parameters.
