Parametric Intergration question
In summary, the area of a circle is given by the integral: \int^{\frac{5\pi}{3}}_{\frac{\pi}{3}} (1-2\cos t)^{2}
thomas49th
655
a curve has parametric equations:
x = t - 2sin t
y = 1 - 2cos t
R is enclosed by the curve and the x axis. Show that the area of R is given by the integral:
[tex]\int^{\frac{5\pi}{3}}_{\frac{\pi}{3}} (1-2\cos t)^{2}[/tex]
Not sure what to do :\
Suppose that the curve was given in the form y = f(x), then how would you calculate the area? Now do the variable substitution from x to t which is given.
You might want to make use of this:
[tex]\int f(x) dx = \int f(t) \frac{dx}{dt} \ dt[/tex]
By the way what's this mathematical property called?
ermm mathematical propety?
dx/dt = 1 - 2cost
i have to multiply this by f(t) (how do i found that) and then intergrate that with respect to t?
Thanks
Yes, the integration is done wrt t. Isn't that given in the answer? And as for f(t), you should know that f(x) in the original integral f(x)dx represents a particular variable. That variable must now be expressed in terms of t for the integration to work.
Hi thomas49th! :smile:
I suspect you're confused by the (x) and the (t).
Just write it [tex]\int f dx = \int f \frac{dx}{dt} \ dt[/tex]
or, in this case, [tex]\int y dx = \int y \frac{dx}{dt} \ dt[/tex] :smile:
ahh yeh it's easy
got it!
cheers :)
The property is called substitution of variables. Probably you've seen it in this form:
Solve [tex]\int \sin(t) \cos(t) \, dt[/tex]; let [itex]u = \sin(t)[/itex], then [itex]du = \cos(t) \, dt[/itex] so [tex]\int \sin(t) \cos(t) \, dt = \int u \, du = \frac12 u^2 + C = \frac12 \sin^2(t) + C[/tex].
You'll notice that in switching from the variable t to the variable u, I replaced [itex]\frac{du}{dt} dt[/itex] by [itex]du[/itex].
If you have never seen this, forget it. Otherwise I hope it clarifies what just happened :)
Related to Parametric Intergration question
What is parametric integration?
Parametric integration is a mathematical technique used to evaluate integrals by substituting the variable of integration with a parameter. This allows for the use of simpler integrals that can be solved more easily.
How is parametric integration different from traditional integration?
Traditional integration involves finding the anti-derivative of a function and evaluating the integral using the fundamental theorem of calculus. Parametric integration, on the other hand, uses a parameter to simplify the integrand and make the integration process easier.
When is parametric integration used?
Parametric integration is commonly used in physics, engineering, and other sciences to solve problems involving complex integrals. It is also useful in situations where traditional integration methods may not be applicable or practical.
What are the advantages of using parametric integration?
Parametric integration can simplify the integration process and make it easier to solve complex integrals. It also allows for the use of different parameters, which can help to generalize the solution and make it applicable to a wider range of problems.
Are there any limitations to parametric integration?
Parametric integration may not always be applicable or provide an accurate solution to a given integral. It is important to carefully choose the parameter and understand the limitations of the technique before using it. Additionally, it may not be suitable for all types of integrals, such as those involving discontinuous functions.
