Parametrizations and regular curves
In summary, the purpose of the variable change in the proof of the theorem is to show that a parametrized curve has a unit-speed reparametrization if and only if it is regular. This is done by using the chain rule and showing that without the variable change, the proof would not be possible. Therefore, the variable change is necessary in order to prove the theorem.
Buri
273
I'd like to have someone explain to me the purpose of the variable change in the proof of the following theorem:
A parametrized curve has a unit-speed reparametrization if and only if it is regular.
Proof: Suppose first that a parametrized curve γ: (a,b) → R^n has a unit-speed reparametrization μ, with reparametrization map φ. Letting t = φ(s) we have μ(s) = γ(t) and so
dμ/ds = (dγ/dt)(dt/ds)
Therefore, ||dμ/ds|| = ||dγ/dt|| ⋅ |dt/ds|
Since μ has unit speed, ||dμ/ds|| = 1, so dγ/dt cannot be zero.
I don't see why it was necessary? Couldn't we have just concluded the exact same thing without the variable change? Another thing, I notice that they use absolute value for |dt/ds| this is because t = φ(s) is a single variable function right? So it's like a 'constant'? Was it just to make this more explicit? Because the norm properties don't have ||fg|| = ||f|| ||g||.
Thanks for the help!
Anyone?
Can anyone help me out on this?
How would you make the conclusion without the chain rule?
You are just taking the norm of a scalar time a vector.
I'm saying we're not supposed to use the Chain Rule. The Chain Rule is obviously necessary, but we could apply the chain rule without having to make such a variable change.
I know the norm property for this, but I don't see how dt/ds is a scalar? Could you explain?
When you say scalar, I suppose you mean that it is a function of one variable plus its a vector valued function - its a 1-tuple. So its norm just simply behaves as a normal absolute value.
right
If the curve is not regular then no reparameterization can regularize it. This follows from the chain rule. I suspect any other proof is equivalent.
If the curve is reparameterized by arc length then this reparameterized curve is regular. But the original curve may not be. To show that it is - use the chain rule.
I don't think you understood my problem. I know you need to use the chain rule. But I don't see the purpose of the variable change in the proof since you can apply the chain rule without making the variable change. So my question was what was the purpose of it...
How do you apply the Chain rule without the change of variables? Can you show me?
FAQ: Parametrizations and regular curves
What is a parametrization?
A parametrization is a mathematical representation of a curve or surface in terms of one or more parameters. It allows us to describe the points on the curve or surface using a set of equations or functions, rather than just listing the coordinates of each point.
What is the purpose of parametrization?
The purpose of parametrization is to simplify the description of a curve or surface and make it easier to work with mathematically. It also allows us to study the behavior of the curve or surface by varying the parameters.
What is a regular curve?
A regular curve is a smooth, continuous curve that does not have any sharp corners or breaks. It can be described using a parametrization, where the parameters vary smoothly and continuously.
What is a singular point on a curve?
A singular point on a curve is a point where the curve is not smooth and the tangent line is not well-defined. This can occur when the parametrization is not differentiable at that point, or when the curve has a sharp corner or cusp.
How are parametrizations used in physics?
In physics, parametrizations are used to describe the motion of objects in space and time. For example, in classical mechanics, the position of an object can be described using a parametrization with time as the parameter. In quantum mechanics, wave functions can be expressed as parametrizations of position and time.
