I Paraxial ray tracing: fixing image/height w/o knowing stop location
In paraxial ray tracing, the marginal and chief rays are used to determine image location and height, with the marginal ray originating from the object's edge and the chief ray from its center. While some resources emphasize the importance of the stop in defining these rays, others suggest that for idealized systems, the angle at which rays are launched is arbitrary and does not significantly affect the outcome. The stop becomes crucial in non-ideal systems, as it influences aberrations and the effective aperture of the optical system. Understanding the relationship between the stop, entrance pupil, and exit pupil is essential for accurate ray tracing, especially when calculating aberration values. Ultimately, for basic image location and height, arbitrary angles can suffice in paraxial ray tracing.
phillip_at_work
TL;DR Summary
Text book (Geary) describes paraxial ray tracing using stop location (marginal ray at height of stop, chief ray through center of stop) to fix image and image height. Example problems across the net use axial/edge rays of arbitrary initial angles. Stop not specified. Why the difference?
In recent coursework, I was taught that one locates the image and identifies the image height using the marginal and chief rays. These descriptions are:
Marginal ray: that ray traced from [top or bottom] of the object, through the outermost edge of the stop. The place where that ray crosses the optical axis is where I will find the image.
Chief ray: that ray traced from [top or bottom] of the object, through the center of the stop. The height of that ray at the image location (defined by marginal ray) is the height of the image.
In an attempt to practice this, I looked for some solutions to replicate (unfortunately, my recent coursework required some ray tracing, but getting the actual solutions for my flawed coursework was difficult or impossible).
I replicated this ray trace on slide 9-9 and 9-10 (two thin lenses in air):
https://wp.optics.arizona.edu/jgrei...11/2019/01/201-202-09-Paraxial-Raytracing.pdf
I can get the same result as the author. However, there is no mention of a stop. Instead, the two rays used to find image/height are launched at arbitrarily small angles. I have seen this elsewhere also. Why?
Tangential question: most resources refer to "stop" when describing system chief and marginal rays. However, does this actually mean entrance pupil? In other words, if the stop is the final component in the system (e.g., stop is exit pupil or "XP"), must I trace this backwards to image that XP as an entrance pupil ("EP") to use that to locate my system chief and marginal rays?
Geary seems to say this explicitly on page 46 (section 5.4): "Suppose we are given the triplet with a buried stop shown in Figure 5.11. We want to trace the marginal and chief ray through the system. But to do that we need to aim the marginal ray at the edge of the entrance pupil and the chief ray at the center of the entrance pupil..."
But other resources on the interwebs seem to contradict or ignore this. For example, this publication seems to use the physical stop to define chief and marginal rays, NOT the EP:
https://spie.org/publications/pm92_161_marginal_chief_rays?SSO=1
Why?
Science news on Phys.org
For paraxial rays it doesn't matter what angle you launch at, so you just pick your favourite. Every ray from the tip of the object will go through the tip of the image; every ray from the on-axis point of the object will go through the on-axis point of the image. For the purposes of this construction you can completely ignore the stop - a ray that doesn't pass through the stop would have ended up in the same place as one that did.
Where the stop starts to become important is when the optical system isn't an idealised linear model (i.e. anything real and non-trivial). Then you need to know which part of each lens/mirror/whatever is in use for an object of interest because it affects the aberration. It's been decades since I did any optical design, so caveat emptor, but I recall that you would typically try to ensure that the stop was the limiting factor in what angles of rays were accepted, but in a non-optimised (or just plain lousy) design you may find that other components "clip" the ray bundle. So I'd say the marginal ray in this context is the most extreme ray from a given point that can make it through the system. You shouldn't need too much trial and error to find the marginal ray if you guess wrong initially - it's a linear system.
As I say, it's been a while since I did optical design, so see what others say too...
Likes tech99 and berkeman
I see. In that case, perhaps the use of paraxial ray tracing to locate the EP or XP is probably just an exercise.
Thanks for your time, much appreciated!
Since my last post, I think I better understand why one would want to conduct a PRT using system marginal and chief rays through pupils.
Many aberration values can be computed using ray heights and angles resulting from a PRT of marginal and chief rays. Tracing rays in this way will also reveal the image location and height.
If one ONLY needs to know the image location and height, one can use PRT with arbitrary initial angles.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
