Parity Check Question -- University Level Intro Course: Networking
In summary, parity check is a method used to detect errors in data transmission by adding a parity bit to the dataword, resulting in a codeword. The receiver then checks if the number of 1's is even or odd to determine if there was corruption during transmission. To generate the codewords, all possible datawords must be considered and a single parity bit is usually added at the end. However, with more redundant bits, errors can be detected and corrected.
SumDood_
30
The size of the dataword is 5 bits. The codewords are created to match all dataword possibilities.
a) Create a table with all the datawords and codewords using parity-check code.
n = k + r
n -> codeword
k-> dataword
r-> redundant bits
What I know:
Parity check is used to detect if there are errors when transmitting data by adding redundancy bits to the dataword (data that we want to send) which creates a codeword. Then the receiver checks if the 1's are even or odd and based on that, we know that there was corruption during transmission.
For example:
dataword = 101
redundancy bit = 0
codeword = 0101
At the receiver side, we check if the 1's are even, if they are, we conclude that the data is not corrupted.
In my question, I do not understand what "all dataword possibilities" mean.
So, the question specifies that I am supposed to use 5 bits for the dataword. This means that from '00000' up to '11111' are valid datawords. I don't know what to do next. Do I just add 1 redundancy bit for 2^5 = 32 datawords? This seems wrong. I feel like I am missing something.
Welcome to PF. :smile:
You basically have it correct. Your table is 2^5 entries of 5 bits each, with one extra parity bit appended at the end to maintain the even or odd parity (whichever is specified) for each codeword. It's often easiest to generate this with Excel, but with only 32 entries you can do it by hand as easily.
https://en.wikipedia.org/wiki/Parity_bit
BTW, a single redundant parity bit can only reliably detect a single bit error in a codeword. With more redundant bits added, you can design the redundant code to detect multiple bit errors and even help with error correction. You'll likely encounter those encodings later in your class.
Likes SumDood_ and pbuk
SumDood_ said:
For example:
dataword = 101
redundancy bit = 0
codeword = 0101
Note that here you have prepended the parity bit (i.e. added it at the beginning). We usually add it at the end (can you think why?), and you have also described adding the parity bit at the end in your question: "n = k + r".
Likes SumDood_ and berkeman
Ah, thanks for pointing that out. I am not sure, though, why it should be added at the end.
From what I know, a single bit would detect an odd number of errors.
Thanks for your help!
