Part 2 of the Fundamental Theorem of Calculus
In summary: This is always the case, so you can just omit it in your calculation.Oh right, how did I miss the cancellation of the constant C? And forget to flip the limits? I kept thinking to myself it looked odd, but never thought to flip it. lol I will be sure not to forget next time. Thanks for all your help!
BlackMamba
187
Hello,
I have a problem that I am getting stuck simplifying further.
The problem asks me to find the integral if it exists using Part 2 of the FTC.
I know that the second part of the FTC says:[itex]\int_{a}^{b} f(x)dx = F(b) - F(a)[/itex] Where F is the anti-derivative of f.
Here is the problem:
[itex]\int_{9}^{4} [/itex] x ^-1 dx
While [itex]f(x) = [/itex] x^ -1 is not continuous throughout it is continuous on the interval [4,9]. So therefore it does exist.
So here is my solution:
[itex]f(x) =[/itex] x^ -1
[itex]F(x) = ln|x| + C[/itex]
[itex]F(4) = ln4 + C[/itex]
[itex]F(9) = ln9 + C[/itex]
Here is where I am having trouble simplifying. I would then use [itex]F(b) - F(a)[/itex]
so when I do that I have [itex]ln4 + C - ln9 + C[/itex]
Could I just write that as [itex]ln4 - ln9 + C[/itex] ? Do I still need to simplify further?
Thanks in advance. :smile:
I'm thinking that I would probably need to simplify further and write it as:
[itex]ln 4/9 + C[/itex]
Would this be correct?
The C's cancel out. Think about it, [itex]\int_9 ^4x^{-1}dx[/itex] is a single number, it doesn't depend on a constant. There is no such thing as THE antiderivative of f, but there is a family of antiderivatives. x |-> ln|x| is one of the antiderivatives. Any function of the form x |-> ln|x| + C is in the family, for any real C. Moreover, only functions of that form are in the family. The theorem should say that if F is ANY antiderivative of f, then
[tex]\int _a ^b f(x)dx = F(b) - F(a)[/tex]
By choosing F(x) = ln|x| + C, you choose an arbitrary antiderivative, but even in this case, when you write F(9) = ln(9) + C and F(4) = ln(4) + C, it's the same C, so they cancel out when you do F(4) - F(9). Alternatively, you could have chosen a particular antiderivative, e.g. the one where C = 0.
No, you forgot to flip your limits of integration. Here:
integral(x^-1 dx, x = 9 to x = 4) = -integral(x^-1 dx, x = 4 to x = 9)
= F(9) - F(4) = ln(9) + C -(ln(4) + C) = ln(9) - ln(4) = ln(9/4) = ln((3/2)^2) = 2ln(3/2)
Notice the constant of integration canceled out. This is always the case, so you can just omit it in your calculation.
Actually I have a similar problem that I could use a bit of help on as well.
I have to find the integral using the same method.
Here's the problem:
[itex]\int_{-\pi}^{\pi} sinx dx[/itex]
So basically it boils down to:
= [itex]-cos\pi + C - (cos\pi + C)[/itex]
= [itex]-cos\pi - cos\pi[/itex]
= 2
BlackMamba said:
= [itex]-cos\pi + C - (cos{pi} + C)[/itex]
That part is wrong, you are missing a - sign, do you see where?
Uhmm not really: Let me try to break it down further.
[itex]F(\pi) = - cos\pi + C[/itex]
[itex]F(-\pi) = cos\pi + C[/itex]
I'm assuming for [itex]F(-\pi)[/itex] that since cos is already negative and that's paired with a negative [itex]\pi[/itex] then that combo would be positive. I'm guessing that is not correct.
cosx is even. This means cos(x) = cos(-x) for every x. So for you, cos(-pi) = cos(pi) = -1. I think you made the mistake and said cos(-pi) = -cos(pi), which is incorrect, since cos(-pi) = -1 and -cos(pi) = -(-1) = 1.
And you should get 0 as the answer btw when you do it so you can check yourself.
I think I'm getting confused. I mean I believe I understand what you are saying. I do recall learning that, but as I've proven before nothing really sticks with me. lol
So if I keep all negative signs in the equations it would look something like:
[itex]F(\pi) = -cos\pi + C[/itex]
[itex]F(-\pi) = -cos(-\pi) + C[/itex]
Which in this case would give me an answer of 0.
Oh you beat me to it. lol Thanks for your help. Next time I better just leave all my negative signs where they belong. :)
Umm... Why do you think he needs to flip the limits? The integral as written above is from 9 to 4, so the anwer would be ln(4/9)=2*ln(2/3).
FAQ: Part 2 of the Fundamental Theorem of Calculus
What is Part 2 of the Fundamental Theorem of Calculus?
Part 2 of the Fundamental Theorem of Calculus is a theorem in calculus that states the relationship between the derivative and integral of a function. It states that if a function f(x) is continuous on the interval [a,b] and F(x) is any antiderivative of f(x), then the definite integral of f(x) from a to b is equal to F(b) - F(a).
How is Part 2 of the Fundamental Theorem of Calculus used in real-world applications?
Part 2 of the Fundamental Theorem of Calculus is used to solve problems involving accumulation, such as finding the total distance traveled by an object with a varying velocity or the total amount of water that flows through a pipe over a period of time. It is also used in economics to find the total revenue or profit from a demand or cost function.
What is the difference between Part 1 and Part 2 of the Fundamental Theorem of Calculus?
Part 1 of the Fundamental Theorem of Calculus relates the integral of a function to its antiderivative, while Part 2 relates the derivative of a function to its integral. Part 1 is used to evaluate definite integrals, while Part 2 is used to solve problems involving accumulation.
What are the conditions required for Part 2 of the Fundamental Theorem of Calculus to be applicable?
In order for Part 2 of the Fundamental Theorem of Calculus to be applicable, the function must be continuous on the interval [a,b] and have an antiderivative. If the function is discontinuous or does not have an antiderivative, then Part 2 cannot be used.
Can Part 2 of the Fundamental Theorem of Calculus be extended to higher dimensions?
Yes, Part 2 of the Fundamental Theorem of Calculus can be extended to higher dimensions through the use of multivariable calculus. In higher dimensions, the integral is defined as a volume under a function, and the derivative is defined as a rate of change in multiple variables. The theorem still holds true in these cases.
