Partial Derivative: Chain Rule
In summary, two cars are approaching an intersection at right angles, one at 60km/h and the other at 80km/h. The distance between them is changing and the question asks for the rate of change when one car is 0.5km from the intersection and the other is 0.7km away. The solution involves setting up position functions for each car, finding the distance function using Pythagoras' theorem, and then calculating the rate of change of the distance function. The final answer is -100km/h.
iamyes
2 straight roads intersect at right angles. Car A, moving on one of the roads, approaches the intersection at 60km/h and car B moving on the other road, approaches the intersection at 80km/h. At what rate is the distance between the cars changing when A is 0.5km from the intersection and B is 0.7km from the intersection?
None. Dont know how. Dont give me the solution, give me a clue i want to try to solve it.
1. Let the intersection be the origin in your coordinate system.
2. Now, let A's position at t (hours)=0 be 0.5 (km) on the right-hand side of the origin.
Then, A's position vector as a FUNCTION of time, A(t) will be:
[tex]A(t)=(0.5-60*t,0)[/tex]
(Agreed?)
Can you set up a similar vectorial position function for B?
3. Now that you have both position functions, how can you find the DISTANCE function, D(t) between them? (Hint: Pythagoras..)
4. You are asked for the rate of change for D(t).
How can you find that?
so..
2) B(t) = (.7 - 80*t , 0)
3) D(t) = (.5^2 + .7^2)^1/2
i can't figure out this one...--->> 4)You are asked for the rate of change for D(t).
2. is wrong, it should be: B(t)=(0, .7-80t)
3. is doubly wrong, since it
a) only gives D(0), rather than D(t)
and
b) calculates it incorrectly from the A(t) and (incorrect) B(t) you set up.
if.. i do it my way, i got the final answer is -100km/h..
is that same as yours?
Post your way, please.
i got dX/dt = -100km/h
That is indeed correct! :smile:
hurmm.. I'm still wondering why did my lecturer told me that there's something
wrong with my solution..:frown:
Well, if you used YOUR version of D(t), then it is a totally incorrect procedure.
The rate of change of THAT expression is just 0.
naspek said:
so..
did u mean by the above D(t)
Quite so.
That function is equal to a constant, its derivative is..0
just for final confirmation...
my calculation and my answer for this question is totally correct
right?
Not if you specified D(t) in the manner YOU did, no.
The answer won't follow from that at all.
could anyone pls give me the solution?
damn I am stuck and it is 3.30am over here
Then follow my hints in post 2.
They are sufficient.
yeah i read all this thread..but still can't do it (im stupid :( )
if anyone could go through everything once again i would be thankful
i can't do it :(
im stupid
and i don't know anything on how to do it
FAQ: Partial Derivative: Chain Rule
What is the chain rule in partial derivatives?
The chain rule in partial derivatives is a method for finding the derivative of a composite function. It states that the derivative of a composite function is equal to the derivative of the outer function evaluated at the inner function, multiplied by the derivative of the inner function.
Why is the chain rule important in multivariable calculus?
The chain rule is important in multivariable calculus because it allows us to find the rate of change of a function with respect to multiple variables. Without it, we would not be able to calculate partial derivatives and solve many problems in economics, physics, and engineering.
How do you apply the chain rule in practice?
To apply the chain rule in practice, you must first identify the outer function and the inner function in the composite function. Then, you take the derivative of the outer function and evaluate it at the inner function. Finally, you multiply this result by the derivative of the inner function.
Can the chain rule be extended to higher dimensions?
Yes, the chain rule can be extended to higher dimensions. In fact, it is a fundamental tool in multivariable calculus, where functions can have multiple input variables. The general form of the chain rule can be applied to functions with any number of variables.
What are some common mistakes when using the chain rule?
Some common mistakes when using the chain rule include forgetting to take the derivative of the inner function, mixing up the order of the derivatives, and not properly identifying the inner and outer functions. It is important to carefully follow the steps and double check your work to avoid these errors.
