Partial derivatives of the function f(x,y)
In summary, the conversation discusses partial derivatives of a function and how they can depend on both x and y. It also mentions the importance of controlling for a variable in order to isolate its contribution to the dependent variable. A visualization app is recommended for better understanding of the surface.
fog37
1,569
108
TL;DR Summary
Hello,
Given a function like ##z= 3x^2 +2y##, the partial derivative of z w.r.t. x is equal to: $$\frac {\partial z}{\partial x} = 6x$$
Let's consider the point ##(3,2)##. If we sat on top of the point ##(3,2)## and looked straight in the positive x-direction, the slope The slope would be ##(6)(2)=12##. In taking the partial derivative, we assume that y is fixed, i.e. kept constant at ##y=2##. However, if we picked a different starting point like ##(3,4)## that has a different ##y## value, the partial derivative would still be equal to $$\frac {\partial z}{\partial x} =12 $$.
But I am envisioning a ##z## curve over the x-y plane that may have a different slope in the x-direction at the point ##(3,4)##. That seems possible. However, $$\frac {\partial z}{\partial x} = 6x$$ does not capture the fact that the local slope in the x-direction may be different at different y locations....Where am I off?
Thanks!
fog37 said:
TL;DR Summary: Partial derivatives of the function f(x,y)
The slope would be (6)(2)=12.
[tex]\nabla z(x,y)=(6x,2)[/tex]
[tex]\nabla z(3,2)=(18,2)[/tex]
[tex]\nabla z(3,4)=(18,2)[/tex]
Fix y and z is a parabola. As functions of y you have a set of parallel parabolas, so for a given x the slope is the same for all.
Likes fog37
Can I add a couple of points to what has already been said.
No, The x-direction slope is ##6x = 6 \times 3 = 18##, not ##12##.
You mean would still be equal to ##18##, not ##12##.
You mean a curved surface over the xy plane. For any point ##(x,y)## the 'height of the surface over that point is ##z=f(x,y)##.
For this particular surface, the x-slope doesn't depend on ##y##. It helps to envisage the surface. If you can't imagine it, there are various 3D plotters available, e.g. look at this: https://www.math3d.org/IGJSjfMEG
Edit.
Likes fog37
Thank you! The surface visualization app helped a lot.
In general, given ##z=f(x,y)##, the partial derivative w.r.t. ##x## can be constant, depend only on ##x##, or depend on both ##x## and ##y##. The partial derivative is the slope at a particular point when we make an infinitesimal step in the x-direction and no step at all in the y-direction. When we say that ##\frac {\partial z} {\partial x}## assumes that we keep ##y## fixed and at some constant level, it does not necessarily imply that that partial derivative cannot depend on ##y## itself (it does only for linear models).
Example: consider the points ##(2,1)## and ##(3,1)##, and the partial derivative $$\frac {\partial z} {\partial x} = 3x+y$$ The slopes are ##7## and ##10##. The ##slope=7## means that constraining/fixing ##y=1##, the derivative is ##\frac {\partial z} {\partial x} = 3x+1##. Keeping ##y## fixed is the same as controlling for the variable ##y##: this means that we are considering the variable ##y## in our model and exploring the change in ##z## for changes in ##x## while #y# is not changing, kept constant. That is what controlling means: considering the variable and keeping it a some fixed value while the other variables change so we can isolate their contributions to the dependent variable.
In the case of multiple linear regression, we could have a model like $$y=3x_1+2x_2$$. We say that 3 is the main effect of ##x_1## when ##x_2## is kept constant because ##\frac {\partial y} {partial x} = 3##. The surface is a tilted plane and the slopes in the ##x_1##-direction are all the same for a a certain value of ##x_1## value regardless of the value of ##x_2##.
If we don't include ##x_2## in our model, we are not controlling for ##x_2## essentially. The ##\frac {\partial y} {partial x}## remains exactly the same, ##3##, even without controlling though...So what is the actual point of including ##x_2## if it really does not change the partial derivative of ##z## w.r.t. ##x_1##?
Sorry for the wordiness...
Sounds like you have the right idea.
Beware of terminology and mixing-up two different things.
Keeping ##y## 'fixed' (at a constant value) is one thing.
But a 'constant level' is usually interpreted (in the present context) as a constant value of ##z##, in the same way that a particular contour on a map indicates a constant height-level.
You can't do both at the same time. So it's confusing to say "we keep ##y## fixed and at some constant level".
On a more general point, for surfaces defined by ##z = f(x,y)## (or using other symbols for the variables) it often helps to visualise the surface and imagine your are on it. Then you can ask what happens to your 'height' (##z##) if you move in a particular direction.
If your function is of the form [itex]g(x) + h(y)[/itex], the partial derivative with respect to one variable will never depend on the other; if you want that then you need a more general form.
FAQ: Partial derivatives of the function f(x,y)
What is a partial derivative?
A partial derivative is the derivative of a function with respect to one of its variables while keeping the other variables constant. For a function f(x, y), the partial derivative with respect to x, denoted as ∂f/∂x, measures how the function changes as x changes, while y remains fixed.
How do you compute the partial derivative of a function?
To compute the partial derivative of a function f(x, y) with respect to x, you differentiate f with respect to x treating y as a constant. Similarly, to find the partial derivative with respect to y, you differentiate f with respect to y while treating x as a constant.
What are the notations used for partial derivatives?
The most common notations for partial derivatives include ∂f/∂x for the partial derivative with respect to x, ∂f/∂y for the partial derivative with respect to y, and sometimes using subscripts, such as fx and fy, to denote the partial derivatives.
What is the significance of partial derivatives in multivariable calculus?
Partial derivatives are significant in multivariable calculus as they provide information about the rate of change of a function in multiple dimensions. They are essential for understanding the behavior of functions of several variables, optimization problems, and in applications such as physics, engineering, and economics.
Can a function have higher-order partial derivatives?
Yes, a function can have higher-order partial derivatives. These are obtained by taking the partial derivative of a partial derivative. For example, the second-order partial derivative with respect to x, denoted as ∂²f/∂x², measures the curvature of the function in the x-direction, while mixed partial derivatives like ∂²f/∂x∂y indicate how the function changes with respect to both variables.
