I Partial Differential Equation solved using Products
The discussion focuses on solving a specific partial differential equation (PDE) using products and concepts from Summability Calculus, particularly with variable bounds for sums and products. The equation in question is $$P^2\frac{\partial^2P}{\partial x\partial y}=(P^2+1)\frac{\partial P}{\partial x}\frac{\partial P}{\partial y}+P\frac{\partial^2P}{\partial y\partial x}$$, with an initial condition of ##P(a-1,a)=1##. The author suggests that while the solution can be derived using Summability Calculus, they are uncertain if a general solution exists without it, as they lack formal PDE training. A participant questions the approach of separating variables into products, indicating a misunderstanding of the method. The conversation highlights the complexities of solving PDEs and the potential limitations of traditional methods.
mathhabibi
TL;DR Summary
The following PDE$$P^2\frac{\partial^2P}{\partial x\partial y}=(P^2+1)\frac{\partial P}{\partial x}\frac{\partial P}{\partial y}+P\frac{\partial^2P}{\partial y\partial x}$$can be solved with products, my question is how to solve without knowing their properties.
Using the concepts of Summability Calculus but generalized such that the lower bound for sums and products is also variable, we can prove that the solution to the following PDE: $$P^2\frac{\partial^2P}{\partial x\partial y}=(P^2+1)\frac{\partial P}{\partial x}\frac{\partial P}{\partial y}+P\frac{\partial^2P}{\partial y\partial x}$$subject to the initial curve ##P(a-1,a)=1## where ##P=P(x,y)## is ##P=\prod_{k=y}^xf(k)##, where ##f(x)## is assumed to be a function defined on the integers. The author goes over different methods of calculating sums of non-integer upper and lower bounds, which can be modified to products as well by simple manipulation. Here the product is generalized to the real numbers, as can be found on pages 17 and 106 (all you need to read), the latter giving a formula for calculation. My question is whether a general solution to this equation can be found without the concepts of Summability Calculus because chances are you've never heard of it until seeing this post. Proving that this is the solution using this field of math is simple by turning to page 17 and using the differentiation rule for products. But I haven't taken a PDE course so I don't know any standard methods to solve this equation.
Mathematics news on Phys.org
As a layman, may I ask you what is the answer solved with products ?
Say
P(x,y)=X(x)Y(y)
The equation is
P(P^2-P+2)X'Y'=0
I don't think that I am on the right track.
anuttarasammyak said:
P(x,y)=X(x)Y(y)
Is not a double variable product because for there to be only two terms either ##x=y+1## or ##y=x-1##. Good observation though.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
