Partial Differentiation of this Equation in x and y
Martyn Arthur
Trying to get to fxx
Please see screen print
Hi;
please see below I am trying to understand how to get to the 2 final functions. They should be the same but 6 for the first one and 2 for the second?
(I hope my writing is more clear than previously)
There is an additional question below.
thanks
martyn
I can't find a standard derivative for cos^2 theta?
Use the chain rule.
Please show your work and don’t simply post images of your result. Type out your work.
Your two first partials are correct, but your notation isn't.
These aren't f(x) and f(y) as you wrote. They are ##f_x(x, y)## and ##f_y(x,y)## respectively. They can also be written more compactly as ##f_x## and ##f_y##.
It might be helpful to think of this as ##(\cos(\theta))^2## and then use the chain rule, as @pasmith recommended.
I agree. In the lower left corner, click on the link that says "LaTeX Guide." A few minutes spent reading that will be very helpful.
Martyn Arthur said:
Homework Statement: Trying to get to fxx
Relevant Equations: Please see screen print
Hi;
No. Why are you saying that?
If you can solve that ##f_x(x,y) = 6x-2y-10## then I'm sure that you can calculate ##f_{x,y}(x,y)##. It's simply the derivative of ##6x-2y-10## with respect to ##y##.
Do something similar for ##f_{y,x}##.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
