MHB Partial Fraction Decomposition Evaluation
The discussion revolves around evaluating the integral of the function $$\int \frac{x^2 - 5x + 16}{(2x + 1)(x - 2)^2} \, dx$$ using partial fraction decomposition. The user initially struggles with the decomposition process, particularly with how to simplify and find coefficients A, B, and C. Key insights include using specific values for x, such as x = 2, to eliminate terms and solve for coefficients, leading to the equations that determine their values. Ultimately, the correct decomposition is found to be $$\frac{3}{2x+1} - \frac{1}{x-2} + \frac{2}{(x-2)^2}$$, making the integration straightforward. Understanding the identity and substitution method is crucial for solving such problems effectively.
shamieh
Ok I'm stuck
I have $$\int \frac{x^2 - 5x + 16}{(2x + 1)(x - 2)^2} \, dx$$
and I got to this part:
$$x^2 - 5x + 16 = A(x - 2)^2 + B(x - 2)(x + \frac{1}{2}) + c(x + \frac{1}{2})$$So do i need to distribute all of these and factor out or is there a simpler way? I found a solution where they are just saying oh x = 2 and plugging it in but I am so lost on how they are getting that random value!
http://www.slader.com/textbook/9780538497909-stewart-calculus-early-transcendentals-7th-edition/493/exercises/20/#
Ok, I see how they got x = 2. they distributed the a(x-2)^2 and then factored it out to get x = 2. Now I'm lost on how they get 5/2c = 10...Where does the 5/2 come from ?
You're missing that if you have an identity any value that you plug into the identity returns a true value. Remember how $(x+1)(x+2) = x^2+3x+2$. How about if I hid the 3 and replaced it with $b$ instead, and told you that $(x+1)(x+2) = x^2+bx+2$. You can plug any number in this equality and get $b$ / true identity. For example, $x = 1$ gives $6 = 1+b+2$ so $3 = b$. In your case they plugged in $x = 2$ because it makes barackets containing A and B zero, leaving out the one containing C.
$\displaystyle \underbrace{(2)^2 - 5(2) + 16}_{10} = A\underbrace{(2 - 2)^2}_{0} + B\underbrace{(2 - 2)}_{0}(x + \frac{1}{2}) + c\underbrace{(2 + \frac{1}{2})}_{5/2}$
Get it?
Hello, shamieh!
Set-up: \frac{x^2-5x+16}{(2x+)(x-2)^2} \:=\:\frac{A}{2x+1} + \frac{B}{x-2} + \frac{C}{(x-2)^2}
x^2-5x+16 \:=\:A(x-2)^2 + B(2x+1)(x-2) + C(2x+1)
This statement is an identity.. It is true for any value of x.
Let x=2\!:\;2^2-5(2)+16 \:=\:A(0^2) + B(5)(0) + C(5)
. . which simplifies to: .10 \,=\,5C \;\;\;\Rightarrow\;\;\; \boxed{C = 2}Let x = 0\!:\;0^2-5(0)+16 \:=\:A(4) + B(1)(-2) + C(1)
. . which simplifies to: .16 \,=\,4A-2B + 2 \;\;\;\Rightarrow\;\;\;4A - 2B \,=\,14Let x = 1\!:\;1^2-5(1)+16 \:=\:A(-1)^2 + B(3)(-1) + C(3)
. . which simplifies to: .12 \,=\,A-3B+6 \;\;\;\Rightarrow\;\;\; A - 3B\,=\,6Solve the system: .\boxed{A = 3},\;\boxed{B = \text{-}1}Therefore:
. .\frac{x^2-5x+16}{(2x+1)(x-2)^2} \;=\;\frac{3}{2x+1} - \frac{1}{x-2} + \frac{2}{(x-2)^2}
$$(x^2-5x+16)/(2x+1)(x-2)^2=a/(2x+1) + b/(x-2) + c/(x-2)^2$$
To find a,multiply both sides by $$(2x+1)$$;
$$(x^2-5x+16)/(x-2)^2=a + b(2x+1)/(x-2) + c(2x+1)/(x-2)^2$$
Now,set 2x+1=0 or x=-1/2,
3=a+0+0=a
To find c,multiply both sides by $$(x-2)^2$$;
$$(x^2-5x+16)/(2x+1)=a(x-2)^2/(2x+1) + b(x-2) + c$$
Now,set (x-2)=0 or x=2,
2=0+0+c=c
Now we know the values of a&c.So,to find b,set x=any number but -1/2 & 2,say 0,
4=3-b/2+1/2--> b=-1
So,the original fraction=$$3/(2x+1) -1/(x-2) + 2/(x-2)^2$$
and the integrating the new fractions is easy.
