MHB Partial fraction decomposition
The discussion focuses on the partial fraction decomposition of the expression 4x²y divided by the product of two quadratic polynomials. A clever algebraic manipulation is suggested to simplify the expression, leading to the identification of 4xy as the difference of two quadratic terms. The proposed decomposition involves expressing the original fraction as a sum of two simpler fractions, each with one of the quadratic polynomials in the denominator. Through coefficient comparison, the values for A and D are determined, resulting in the final decomposition of the expression. The solution demonstrates an effective approach to tackling complex algebraic fractions.
Drain Brain
please help decompose$\frac{4x^2y}{(x^2-2xy+2y^2)(x^2+2xy+2y^2)}$
I've used the cases I know for this problem but to no avail. please help me.
Mathematics news on Phys.org
This takes a bit of trickery, note that :
$$\begin{align}\frac{4x^2y}{(x^2-2xy+2y^2)(x^2+2xy+2y^2)} &= \frac{x \cdot 4xy}{(x^2-2xy+2y^2)(x^2+2xy+2y^2)} \\ &= x \cdot \frac{(x^2+2xy+2y^2) - (x^2-2xy+2y^2)}{(x^2-2xy+2y^2)(x^2+2xy+2y^2)}\end{align}$$
Can you proceed?
Can you proceed?
sure, from here It seems that I can decompose it. but how come you replaced $4xy$ to $(x^2+2xy+2y^2) - (x^2-2xy+2y^2)$ ??
Uh, not sure if I understand your question, but it follows from basic algebra
$$(x^2+2xy+2y^2) - (x^2-2xy+2y^2) = \cancel{\color{red}{x^2}} + 2xy + \cancel{\color{green}{2y^2}} - \cancel{\color{red}{x^2}} + 2xy - \cancel{\color{green}{2y^2}} = 2xy + 2xy = \boxed{4xy}$$
While mathbalarka's suggestion is quite clever and makes light work of the problem, I would have assumed the decomposition would take the form:
$$\frac{4x^2y}{\left(x^2-2xy+2y^2\right)\left(x^2+2xy+2y^2\right)}=\frac{Ax+By+C}{x^2-2xy+2y^2}+\frac{Dx+Ey+F}{x^2+2xy+2y^2}$$
and then plodded along with the resulting cumbersome algebra.
Hence:
$$4x^2y=(Ax+By+C)\left(x^2+2xy+2y^2\right)+(Dx+Ey+F)\left(x^2-2xy+2y^2\right)$$
$$4x^2y=(A+D)x^3+(C+F)x^2+(2A+B-2D+E)x^2y+(2A+2B+2D-2E)xy^2+(2C-2F)xy+(2C+2F)y^2+(2B+2E)y^3$$
Comparing coefficients, we obtain:
$$A+D=0$$
$$C+F=0$$
$$2A+B-2D+E=4$$
$$A+B+D-E=0$$
$$C-F=0$$
$$B+E=0$$
From the 2nd and 5th equations, we immediately find:
$$C=F=0$$
From the 1st, 4th and 6th, we find:
$$B=E=0$$
Thus, we are left with:
$$A=-D$$
$$A=D+2$$
Thus, $$A=1,\,D=-1$$ and so we find:
[box=green]$$\frac{4x^2y}{\left(x^2-2xy+2y^2\right)\left(x^2+2xy+2y^2\right)}=\frac{x}{x^2-2xy+2y^2}-\frac{x}{x^2+2xy+2y^2}$$[/box]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
