MHB Partial fraction decomposition
lucad93
Hello everybody! I have to decompose to simple fractions the following function: $$V(z)=\frac{z^2-4z+4}{(z-3)(z-1)^2}$$. I know I can see the function as: $$V(z)=\frac{A}{z-3}+\frac{B}{(z-1)^2}+\frac{C}{z-1}$$, and that the terms A, B, C can be calculated respectively as the residues in 3 (single pole), 1 (double pole), and 1 (single pole). So i calculate: $$A: Res(f, 3) = 1$$, that's correct; $$B=Res(f,1) = \lim_{{z}\to{1}}\left[\d{}{x}z^2-4z+4\right]=-2$$, that's correct. Finally I have to calculate the $$Res(f,1)$$, single pole. I tried in some ways: by using the single pole formula and then using the "de l'hopital"'s theorem, by calculating the decomposed function in 0 and then equaling to the function in 0, but nothing was correct. Can you tell me a correct way to proceed? Thankyou
Put the partial fraction back over a common denominator:
V(z)=\frac{A}{z-3}+\frac{B}{(z-1)^2}+\frac{C}{z-1}=\frac{A(z-1)^2+[B+C(z-1)](z-3)}{(z-3)(z-1)^2}
The coefficient of $z^2$ in the numerator is $A+C=1 $
(z^2-4z+4)/(z-3)(z-1)^2 = 1/(z-3) - 2/(z-1)^2 + C/(z-1)
Now,plugging any number into z,say 0;
-4/3 = -1/3 -2 -C .Then,
C=-1
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
